(ECU) need help
From: IN YOUR BASEMENT, ON YOUR COMPUTER, minesota, united states
ok i have a 88 crx and im doing a b16a jdm swap and i was just wondering if i can use my ecu that i have now (obd0) get the engine to work and get the v-tec to kik in fine. or em i going to get a whole new wiring harness and a new ecu.
tryed using search but dint find any thing i could use.
OK......first search is your friend...........second i assume its an si or an hf, and are running pm6, I WOULD RECOMMMEND PR3 OR PW0....... oh and about harness you can either build your own or buy one @ http://www.rywire.com..... its called a vtec subharness i beleive......... if you have dpfi you will have to convert to mpfi......good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">612-229-8103 if you need immediate assistance
GOOD LOOKING out.........fellow h-t'er!
</TD></TR></TABLE>GOOD LOOKING out.........fellow h-t'er!
do 88 crx si have mpfi because im looking at my motor and im looking at the harness and it seems that i have more wires on the b16 then i have on the harness.
i cant tell if its because of the V-tech wires or just simply because its dpfi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">pm me man I am local might even be able to help.
-Shane</TD></TR></TABLE>
hey, if you could stop by my house i would really appreciate it this is my first engine swap and every thing, but i have some wat of an idea on wat im doing but i still dont have that big of an idea ill try giving you a call tomorow. so if you could stop by and tell me wat you think.
yeah man hit me up tomorrow I can come out on Saturday for sure. Pretty much open the whole day. Going to be welding in a new muffler since my muffler is missing the bottom of it
-Shane
. -Shane
by the way its vtec (not v-tec, vtech, v-tech, or VTEK)
As far as the wiring goes. Also I may be able to make a obdo-1 jumper harness if you want to go obd1. (made my own not that hard).
To tell if you have MPFI look at the fuel injector plugs if there are 4 then you got the correct one if you have 2 then got the wrong one.
84-91 CRX SI came MPFI
All you should have to do is add vtec wiring, oxygen sensors (matters which ecu you are running), and I forget if JDM b16a came with a knock sensor, may have to relocate the water temp gauges too.
. As far as the wiring goes. Also I may be able to make a obdo-1 jumper harness if you want to go obd1. (made my own not that hard).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDietrich84 »</TD></TR><TR><TD CLASS="quote">just dont put a blower on this one
yeah ill have to take that advice, yeah shane ill give you a call tommorow then
</TD></TR></TABLE>yeah ill have to take that advice, yeah shane ill give you a call tommorow then
Hey man I sent you an IM if you don't know how to check it click on the thing under your screen name (HondaRexBoi) under the year you joined on the right.
Its a little balloon with IM in it. Click on it. Say hi to me or something and then hit send. It will show what I wrote.
(thats the easy way to do it for a newcomer)
Hit me back cause you are definately going to need help with that wiring.
-Shane
-Shane
PDRIFT86
Apr 11, 2007 09:20 PM
nissaninahondaworld
Dec 22, 2005 08:06 AM
cramers coupe
May 29, 2005 05:50 PM
kim_2_da_chee
Apr 15, 2004 11:43 AM
