97 Gsr into 97 Civic hatch... diirect bolt swap???
Ive heard that the 97 gsr would bolt right into the civic with little or no extra mods. But ive noticed that the drivers side gsr's engine mount looks diferent than the civic driver side engine mount on the target car. I will soon be posting pics for a better idea. If any one knows wat i should do about the two enigine mounts let me know. Thanks ahead!
im pretty sure all the brackets but the post mount will work.....you will need to get that bracket off an 99-00 si or a 90-93 da
thanks ill give it another look see... would i remove the gsr mount...? and should it go onto the si mount?
you wiil need a 99-00 civic si rear bracket, and the right motor mount bracket(driver side) out of a 99-00 si or a 94-97 del sol equiped with a b series, everything else is cake, u r going to use the EK harness and just add up the vtec,vtec oil press, and knock wires to the ecu
NA IS BEST!!
NA IS BEST!!
Yeah you also might need to change a few plugs here and there and extend a wire or two. It would be even easyer if you could find an EX EK wiring hardness... Also you will need a gsr throttle cable unless you can getto rig your stock one( I did this at first but the throttle was only opening 3/4 of the way). I have found that the stock fuel line is a bit short for the B18. The rest you will figure out as you go...
slowassBubble
Oct 3, 2010 04:24 PM
r1whore
11
Jun 26, 2008 08:32 AM
civicmobileone
Apr 25, 2007 12:38 PM
mugen97ek
Jun 6, 2005 12:35 PM
THugluv423
Mar 23, 2005 07:55 PM
