strips in wheel wells cause rust?
Old Aug 20, 2005 | 01:27 AM
7808's Avatar
Default strips in wheel wells cause rust?
i dont know if newer hondas have these cause i never own"newer" cars, but as for my 96 prelude, 90 civic, and my current 90 accord, they always rust out above the back wheels here in MN, like even 98s will be sportin some rust,
i heard i forgot where that the rubber-ish strips on the edge of the fenders inside the wheel well hold road salt in (we salt the roads here in the winter) and cause this nastyness. true? i have a friend that just ripped the strips out, there just kinda fit on and pull right off.
Old Aug 20, 2005 | 01:28 AM
ceLtic*
Guest
Posts: n/a
Default Re: strips in wheel wells cause rust? (7808)
this is TRUE.
Old Aug 20, 2005 | 03:43 AM
Targa250R's Avatar
be professional
This is true. And no, none of the newer Hondas have them.
Old Aug 20, 2005 | 03:55 AM
CWBETB's Avatar
I take mine off in the summer and put them on in the winter. Reason why is because in the winter they throw alot of salt/rocks around my area and it will chip the paint in the wells then salt will lay in it causing rust. Summer time I just let them "air out". If you have them on all year round its not a bad idea to remove them and clean inside a few times a year. "I would also do this under mud flaps as well"
Old Aug 20, 2005 | 05:37 AM
Mattamotor's Avatar
Default Re: strips in wheel wells cause rust? (CWBETB)
Put them on full of motor oil and it will stop rusting.
Old Aug 20, 2005 | 07:57 AM
Desired_Speeds's Avatar
yea, they do, I have a rust bubble from them now, i gotta take off the other side just incase
Old Aug 20, 2005 | 08:27 AM
WhiteSlips's Avatar
Default Re: strips in wheel wells cause rust? (Desired_Speeds)
Pull them off for sure! They rusted out my rear quarters sooo bad.
PowerLeg
Jul 3, 2010 11:17 AM
jonhstarkironman
Oct 16, 2009 10:59 PM
TheMuffinMan
Aug 29, 2009 09:59 AM
peanut butter
Paint and Body
Feb 23, 2008 03:22 PM
