14.14 in 4 door h22 civic
Old Aug 19, 2005 | 08:21 PM
LDS's Avatar
LDS
Default 14.14 in 4 door h22 civic
I have ran a new best of 14.14 and 14.16 with mph between high 96 and mid 97.
these new times are on 22X8 slicks. im happy for now but need to retune my ecu. Mph on street tires is 98.2s.
Dont forget my car is full weight 4 door civic ex so I think my times arent all that bad.
Old Aug 20, 2005 | 01:07 AM
rjay8604's Avatar
Default Re: 14.14 in 4 door h22 civic (LDS)
I'd say those times are pretty good. Although i would say in ideal conditions, you'll probably be able to break 13's.
Old Aug 20, 2005 | 03:32 AM
hondaguyef's Avatar
Default Re: 14.14 in 4 door h22 civic (rjay8604)
What did your 60's look like? 1.8's?
Old Aug 20, 2005 | 04:34 AM
1700anddroping's Avatar
Default Re: 14.14 in 4 door h22 civic (hondaguyef)
gotta love the H SERIES.....
HARV
good times for a 4 door no doubt.
Old Aug 20, 2005 | 11:53 AM
LDS's Avatar
LDS
60fts were 2.12 and 2.15 cause i rolled it a lil out the hole so i wouldent break an axle.
Old Aug 20, 2005 | 11:59 AM
hondaguyef's Avatar
Default Re: (LDS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS &raquo;</TD></TR><TR><TD CLASS="quote">60fts were 2.12 and 2.15 cause i rolled it a lil out the hole so i wouldent break an axle.</TD></TR></TABLE>
Why is everyone so scared of breaking axles? I launch at 6500+ (depending on the track) on stock axles w/ my current setup. I've launched at 8K before w/ my NA setup on OE axles both cases on slicks. The turbo'd car usually cuts low 1.8's and the NA setup cut low 1.7's consistently. Now that I'm done ranting, 13's are definately in your near future. Don't be scared to lauch that bitch!
Phil
Old Aug 20, 2005 | 12:05 PM
LDS's Avatar
LDS
What psi do you run in your slicks? Also what do you think i should run in mine? I weigh 2600 pounds or so slicks are 22x8 M/t 15inch.
Last time I ran these slick was on my 99 si and i kept bogging out the whole then i launched it at 8 grand a blew a hole in the tranny, thats why im scared LOL.
Thanks in advance.
Old Aug 20, 2005 | 12:08 PM
hondaguyef's Avatar
Default Re: (LDS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS &raquo;</TD></TR><TR><TD CLASS="quote">What psi do you run in your slicks? Also what do you think i should run in mine? I weigh 2600 pounds or so slicks are 22x8 M/t 15inch.
Thanks in advance.</TD></TR></TABLE>
With my NA setup I used to run 11 psi in the slicks (play w/ psi at different tracks though). Do a search on here for "preload" or "preloading". I do that on every launch and have yet to break a drivetrain component w/ this method :knocks on wood: Hoep that helps.
Phil
Old Aug 20, 2005 | 02:39 PM
AllMotorCrxRACECAR's Avatar
Default Re: (hondaguyef)
my buddy in his 4dr 93 stock weight ran 13.50 stock 94 h22 on a BFG radial 101mph
Old Aug 20, 2005 | 03:13 PM
LDS's Avatar
LDS
Default Re: (AllMotorCrxRACECAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorCrxRACECAR &raquo;</TD></TR><TR><TD CLASS="quote">my buddy in his 4dr 93 stock weight ran 13.50 stock 94 h22 on a BFG radial 101mph</TD></TR></TABLE>
What mods did he have done? I know you say stock but does he has intake or header or exhaust? What s his timing? Anything that you can share would be great so I can get my car were it should be.
Thanks.
Old Aug 20, 2005 | 07:11 PM
Honda Bull's Avatar
Default Re: (LDS)
Like hondaguyef said... play with pressures and launch RPM. And if you do travel to different tracks... start with a fairly high pressure in the tires... never want to underestimate the traction available at different tracks. Better to spin to hell and back than to bog and stress stuff.
You could definately get mid 1.9s most likely if you launch it around 7200 or so rpm. But I see you're trying to sell it so... oh well.
Fast 4-doors are sweet.
Old Aug 21, 2005 | 03:34 PM
Bserieskllr's Avatar
yea whats the point of using the slicks if your not even gonna put them to good use i pulled those 60's on azenis oh and your 99si was prolly bogging because 22inch slicks are a little tall for heavy b16 coupe with very little tq.
Old Aug 21, 2005 | 04:57 PM
LDS's Avatar
LDS
Ok once again like i stated in my first post i wanted them mainly for the 1-2 shift so i wouldnt spin from 40-60 mph.
I heard azenia tires are bad *** glad to hear you got good use from them. I feel a little more comfortable with the slicks now cause i made 6 passes on them and everything feels fine. I did though pull a 2.07 60ft but i missed a gear wich kinda sucks cause i think that was my ticket to a 14.0-13.99 pass.
Thanks for you input thogh.
Old Aug 21, 2005 | 05:12 PM
93H22ACX's Avatar
Default Re: (LDS)
nice times..
dont be afraid of breaking axles...both our cars run stock axles... and we use 26"and 25" slicks.... 5psi of air also
if you dont launch hard you wont get the full benefit of your setup and slicks....
just preload and you'll be fine. good luck next time...
Old Aug 21, 2005 | 06:01 PM
LDS's Avatar
LDS
I did a search for preloading and didnt get anything . Can you explain?
Old Aug 21, 2005 | 07:14 PM
rjay8604's Avatar
Default Re: (LDS)
To preload simply engage the clutch partially when you stage so that the driveline and suspension are already loaded with force, use the E-brake with firm pulling to keep the car in place, when you take off, there is no shock from No load to Full load of the launch, instead the force goes straight to the ground. Its kinda like when you pull a ratchet steadily, and then sometimes you use a hammer to create a high peak force to break loose the nut/bolt. You doing just the opposite, trying to prevent a sudden jolt or shock of force. I hope i didn't make that confusing as hell.
Old Aug 23, 2005 | 03:15 PM
LDS's Avatar
LDS
Thank you I will try that next time I go out. Do you guys pull a better time when doing this vs not preloading?
Old Aug 24, 2005 | 03:38 AM
93H22ACX's Avatar
Default Re: (LDS)
well depending on how you do it, yes... we've pulled 1.5 60ft to 1.7 60ft preloading and ran 9's and 10's on stock axles (OEM and Autozone)...
Old Aug 24, 2005 | 02:02 PM
LDS's Avatar
LDS
Default Re: (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">well depending on how you do it, yes... we've pulled 1.5 60ft to 1.7 60ft preloading and ran 9's and 10's on stock axles (OEM and Autozone)...</TD></TR></TABLE>
9's on OE axles got to love that LOL.
Old Aug 24, 2005 | 02:54 PM
mudshuvelz's Avatar
Default Re: (LDS)
autozone axles..get lifetime warranty it only takes 15 mins to replace
Old Aug 25, 2005 | 05:12 PM
LDS's Avatar
LDS
Default Re: (mudshuvelz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mudshuvelz &raquo;</TD></TR><TR><TD CLASS="quote">autozone axles..get lifetime warranty it only takes 15 mins to replace </TD></TR></TABLE>
dont forget I have to frankenstine the axles for them to work.
Old Aug 25, 2005 | 06:26 PM
mudshuvelz's Avatar
Default Re: (LDS)
i understand. you just take the inner part of the shaft off the old axle and reclamp the boot on
Old Aug 26, 2005 | 08:02 PM
LDS's Avatar
LDS
Ah I see what your saying now. But i would have to do a good job putting them back to gether if i had to return them.
Old Aug 27, 2005 | 04:45 AM
mudshuvelz's Avatar
Default Re: (LDS)
when u want to get a new one make sure u dont give them your prelude inner, give them the 92-95 ls inner. and u dont even have to have it together or the boot
red eg1
Dec 10, 2005 07:43 AM
powderz
Jan 25, 2005 03:24 PM
PM-Performance
Jun 21, 2004 02:33 AM
nacho
26
Sep 17, 2003 05:14 PM
fuzzynutz
May 18, 2003 04:50 PM
