car shake at Idle and under 1000 RPM...
Old Aug 19, 2005 | 08:10 PM
ttvegas2002's Avatar
Default car shake at Idle and under 1000 RPM...
Hi guys,
My care shake at Idle and if I turn on my ac then it getting worst, but if I rev over 1000 RPM then the raddle or the shaking slowly went away.. could anyone help me out? Thanks in advance
Old Aug 19, 2005 | 08:21 PM
YeuEmMaiMai's Avatar
Default Re: car shake at Idle and under 1000 RPM... (ttvegas2002)
could be engine mount
could be a misfire on one of your cylanders due to various reasons
could be vacume line
Modified by YeuEmMaiMai at 12:09 AM 8/20/2005
Old Aug 19, 2005 | 08:45 PM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ttvegas2002 &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys,
My care shake at Idle and if I turn on my ac then it getting worst, but if I rev over 1000 RPM then the raddle or the shaking slowly went away.. could anyone help me out? Thanks in advance</TD></TR></TABLE>
What year of car. The 90-93 accords are terrible at this problem and may be tranny related. Although my 89 se-i does this only at a stop with steering wheel shake. I have not looked into it as I am doing a 5 sp swap soon and will probably replace engine mounts as well. But its the wifes car so I am still happy.
Old Aug 19, 2005 | 10:37 PM
deserthonda's Avatar
like it was advised chk motor mounts ,,especially the rear and especially if it is auto tranny , also make sure u get vaccum at the rear motor mount diaphram when idle is 750 or below .... a good way to chk rear mount if put a floor jack under tranny and slowly raise car while watching rear mount ,if broken u can see the mount pull apart , as for the frt mount just look to see if broken . pull back the rubber flap and look at mount , the top part is the 1 that brakes on frt mounts ..
confucius
Jun 16, 2017 09:20 AM
Norac1983
Jun 28, 2011 06:30 PM
confucius
May 23, 2005 10:18 PM
threatcon13
Apr 13, 2003 01:33 PM
