igniter help
Old Aug 19, 2005 | 06:24 PM
1SlowB16EF's Avatar
Default igniter help
just want to double check my igniter wires are wired to the correct spade terminals .
does anyone have a good diagram as to which wires (+) (-) trigger and tach go to position wise on the igniter?
from memory i believe that with the igniter installed in the dist the tach goes to the single spade on the side of the igniter
the top spade it the trigger to the coil
middle spade is the (+)
and the bottom spade is the (-)
can anyone verify this is correct or provide some input or diagrams
i have a honda shop manual but it does not give accurate spade positions
by the way its a obd1 dist
DamnThatsRexy
May 26, 2013 10:02 AM
sniffthese
Aug 15, 2005 04:29 PM
iwouldHITit
Apr 14, 2003 12:09 PM
91hatchcivic
Aug 1, 2002 11:39 PM
