mini me swap....oil pressure sensor?
after i wire up a vtec controller(rpm switch) what do i do to the oil pressure sensor below the vtec solenoid...do i just ground it out? what power gains should i be looking at( d15b2 block, z6 head...mpfi conversion...si ecu) whats the best rpm to set the controller at....help would be appreciated
