how diagnose D4 light flashing on a '95?
Old Aug 19, 2005 | 05:25 PM
regder's Avatar
Default how diagnose D4 light flashing on a '95?
just today my D4 light started flashing after driving for about an hour. If I turn the car off and imediately restart it, the light will stop flashing for another hour before starting again. My check engine light does not come on
it's a '95 so it's OBD1, how can I check what code is coming up?
Old Aug 19, 2005 | 05:52 PM
projectTeG's Avatar
i think you need to pull the code from the tcm, if its the same on the integra as it is one the cb7 accords, then you do everthing for pulling a code from the ecu, but one of the atuo indicators will blink. and go from there....id say check in a manual
Old Aug 19, 2005 | 11:38 PM
regder's Avatar
ok, so I've tried to read the code through the service port by shorting it with a paper clip
either I'm doing it wrong, or well I'm probably doing it wrong. If I turn the car off and then turn the ignition to on, nothing happens. If I drive the car with the connector shorted and wait for the light to start blinking, it will just blink without showing a code.
Remember, if I turn the car off for even a second the light will stop flashing
what can I do?
Old Aug 20, 2005 | 08:59 AM
regder's Avatar
anyone?
Jerkface38
Honda Civic (2001 - 2005)
Mar 28, 2013 04:52 PM
M15
20
Aug 13, 2005 12:49 PM
UpstateCivic
Jun 7, 2003 12:27 PM
kayoken
Feb 5, 2003 08:12 PM
