How do i rewire my 02 sensor??? "1 wire 02 sensor" to "4 wire 02 sensor"
Old Aug 19, 2005 | 05:22 PM
DaCRXboi's Avatar
Default o2 sensor help and intake question
i need help on putting an 4 wire 02 sensor on my crx with a LS swap, and im useing my stock 89crx wireing harness and it have only one wire 02 sensor. PLZ HELP!!!
also can u tell me which kind of intake should i buy?? do i buy it for the same car model or the motor year??? least i did a motor swap.
Modified by DaCRXboi at 8:16 PM 8/19/2005
Old Aug 19, 2005 | 09:46 PM
exsinnovation's Avatar
Default Re: o2 sensor help and intake question (DaCRXboi)
Perhaps a search would help! the search should be your best friend. unless you wanna get flammed for not unsin it..
Old Aug 20, 2005 | 01:44 PM
ijjz's Avatar
wire one ground and a hot wire together, and run that to a ground source.
wire the other hot wire to a powered source (only on when car is on)
then wire the signal wire to where its supposed to be.
Old Aug 20, 2005 | 03:47 PM
Rywire's Avatar
Default Re: o2 sensor help and intake question (ijjz)
what ecu do u have? obd1?
Old Aug 20, 2005 | 04:19 PM
DaCRXboi's Avatar
yeah i have an odb1 ecu p75
Old Aug 20, 2005 | 04:46 PM
Rywire's Avatar
the green is a ground, the white is signal, and the blacks can be switched... one is 12volt, and the other is heater control, They need to be wired correctly to work
Ryan
Old Aug 20, 2005 | 06:27 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: o2 sensor help and intake question (droppedcrxsi)
Thanks Ryan for answering this question correctly.
Old Aug 20, 2005 | 10:40 PM
DaCRXboi's Avatar
Default Re: o2 sensor help and intake question (mar778c)
thx alot
juanchoenuncrx
Aug 24, 2007 04:48 AM
CRVRX
50
Feb 28, 2006 04:55 AM
roc
Apr 25, 2003 04:57 AM
