Got my car tuned today DYNO SHEET
Old Aug 19, 2005 | 04:04 PM
TEG777's Avatar
Default Got my car tuned today DYNO SHEET
got my car tuned today, it is a 97 integra LS, here is my setup
b18b motor
.57 trim turbo
450cc injectors
2.5 inch piping, and downpipe
tuned with uberdata
i have a 6 pound spring with no boost controller, it only held 4.5psi on the dyno, so here are the results
http://www.we-todd-did-racing....x.jpg
please give me your advice on what i can improve, iam going to get it re dynoed with a boost controller running 8psi
Old Aug 19, 2005 | 04:12 PM
11SEC CIV's Avatar
Default Re: Got my car tuned today DYNO SHEET (boostinteg777)
ummmm ......I would recheck all your charge pipes and make sure you are actually boosting
Old Aug 19, 2005 | 04:18 PM
TEG777's Avatar
Default Re: Got my car tuned today DYNO SHEET (12SEC CIV)
what do u mean, it showed 4.5 psi on the dyno
Old Aug 19, 2005 | 04:19 PM
Makdaddynuge's Avatar
those numbers are extremely low, i would think it should make atleast 180 with 4.5 psi.
Old Aug 19, 2005 | 05:32 PM
2kTeg's Avatar
Default Re: (Makdaddynuge)
anrn't those the stock numbers for a b18b??
Old Aug 19, 2005 | 05:35 PM
xenocron's Avatar
Default Re: (2kTeg)
Peak Torque at 3500 rpms...YIKES!
Something is definitely wrong...
Old Aug 19, 2005 | 05:42 PM
EBP.EM1's Avatar
Default Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Peak Torque at 3500 rpms...YIKES!
Something is definitely wrong...</TD></TR></TABLE>
werd
Old Aug 19, 2005 | 08:14 PM
Griffin@Camtech's Avatar
Default Re: (1slow4dr)
tell um its all motor
thats way to low for a turbo b18 even at 4.5psi
Old Aug 19, 2005 | 08:29 PM
Adi Radoncic's Avatar
On Fire!
I really don't think there is anything wrong with the numbers he's got, a stock ls would never make 140whp on a mustang dyno. The motor itself is rated at 140hp at the flywheel not at the wheels from the factory.
I say put the car on a dynojet and you'll c the power jump!
Old Aug 19, 2005 | 08:32 PM
TEG777's Avatar
Default Re: Got my car tuned today DYNO SHEET (Adi Raaa)
so there is nothing wrong, because i even thought that i would make about 170 wheel horsepower, the guy at the shop said that 145 is normal for the psi iam running
Old Aug 19, 2005 | 08:39 PM
abnaasefmb's Avatar
uh, nice tq........i guess.
Old Aug 19, 2005 | 08:59 PM
TEG777's Avatar
Default Re: Got my car tuned today DYNO SHEET (abnaasefmb)
anymore comments or tips
Old Aug 19, 2005 | 09:12 PM
ATS*Mark's Avatar
OG triple OG
get a 10 dollar mbc and please up the boost to 12 lbs.
Old Aug 19, 2005 | 09:17 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinteg777 &raquo;</TD></TR><TR><TD CLASS="quote">anymore comments or tips</TD></TR></TABLE>
4.5psi isnt even worth having a turbo setup in my opinion... double digits or go home
Old Aug 19, 2005 | 09:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Got my car tuned today DYNO SHEET (dunkd)
i agree
Old Aug 20, 2005 | 05:13 AM
TEG777's Avatar
Default Re: Got my car tuned today DYNO SHEET (Hella_JDM)
i have a 6 psi spring, but for some reason it only help 4.5 psi
Old Aug 20, 2005 | 05:18 AM
95cxh22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">4.5psi isnt even worth having a turbo setup in my opinion... double digits or go home </TD></TR></TABLE>
ditto.
Old Aug 20, 2005 | 05:32 AM
blackeg's Avatar
good thing im at 11psi
as 12sec civ said earlier, go back over your pipes, especially the couplers and make sure they arent leaking. one of my friends was set to boost 10 psi, but he was only seeing about 4 to the motor because the coupler on his throttle body was broken on the bottom and had a huge hole in it
Old Aug 20, 2005 | 08:22 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinteg777 &raquo;</TD></TR><TR><TD CLASS="quote">got my car tuned today, it is a 97 integra LS, here is my setup
b18b motor
.57 trim turbo
450cc injectors
tuned with uberdata
please give me your advice on what i can improve, iam going to get it re dynoed with a boost controller running 8psi</TD></TR></TABLE>
Just FYI, I had a 91 Integra witha shitty *** Gude Head package(cams, header, intake mani ported, ported head, ecu) and it made 144whp and 126 ft-lb torque back in 99(no fuel tuning either), I say definately something is wrong here my friend. Check charge pipes, make sure your turbo doesn have excessive shaft play, make sure your compression is good in all cylinders. With a 57 trim turbo you should've made at least 170 plus whp even at that boost. Check your tune too! Good luck bro.
Old Aug 20, 2005 | 08:42 AM
On Fire!
Default Re: Got my car tuned today DYNO SHEET (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
Just FYI, I had a 91 Integra witha shitty *** Gude Head package(cams, header, intake mani ported, ported head, ecu) and it made 144whp and 126 ft-lb torque back in 99(no fuel tuning either), I say definately something is wrong here my friend. Check charge pipes, make sure your turbo doesn have excessive shaft play, make sure your compression is good in all cylinders. With a 57 trim turbo you should've made at least 170 plus whp even at that boost. Check your tune too! Good luck bro. </TD></TR></TABLE>
Was that on a mustang dyno or dynojet terry?
Old Aug 20, 2005 | 08:49 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Raaa &raquo;</TD></TR><TR><TD CLASS="quote">
Was that on a mustang dyno or dynojet terry?</TD></TR></TABLE>
Sorry it was on a Dynojet sir
Old Aug 20, 2005 | 02:23 PM
TEG777's Avatar
it was a mustang dyno
Old Aug 22, 2005 | 09:28 AM
TEG777's Avatar
anyone else have any input
Old Aug 22, 2005 | 09:34 AM
wpgcivic's Avatar
on a stock single cam with a tiny td05 at 7 psi i made 162 so yeah check things over
Old Aug 22, 2005 | 09:44 AM
wisjdmhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">get a 10 dollar mbc and please up the boost to 12 lbs.</TD></TR></TABLE>
