civic wagon 1991-1985 pics
looking for pics of fixed up wagons. going to get a wagon so i wanted to see what it might look like. it might be a 1991 white but i would not mind if its pics of other years as well. so can you guys post up pics here of all of those hot looking fixed up wagons.
Good luck finding pimped wagons. They exist, but they are VERY difficult to find and even fix up if you have the 4wd version. 99% of the standard parts do not fit, there are no body kits/mods sold for it, and interior upgrades are virtually impossible without destroying OEM parts. I looked into purchasing one for myself, but my hatch fell into my lap at the last minute. The EF-based models are sweet, if you get one, take care of it as it might be worth money sometime down the road.
Well... EF, meaning generation based on JDM VIN, is the 88-91 Civic/CRX generation. Most people believe that this was the pinnacle of refinement in the Civic generation. They continued to get heavier and this was also the first generation that came with Vtec as an option in higher end models and was the last generation of the real racing CRX and the wagon models (the del Sol does not count, it was badged a CRX outside the US, but it only looked the part halfway and performed terribly). Most US and Canadian variants of this generation are technicallty "ED"s but most identify them with the JDM EF. My opinion (and some will disagree, as with any opinion) is the 88 Hatch Std was the best model due to the excessively light weight and the ability to use pre-EF generation motors and interior parts as well as post-EF generation motors and basically everything else. Some of the best upgrades you can do to the EF generation come from the 94-2001 Integra with the center console including cup holders and arm rest (neither of which came on any EF model). Search around, you will notice those that drive this generation Civic/CRX are VERY devoted to the EF and look down on most other models (of Civics) as half-assed tries to copy the original power to weight ratio of the EF models (I do and I think that anything afterwards with few exceptions are heavy pigs, EG lovers this does not include you).
I am very biased, of course, and I love my beater "ED" very much. Good luck and happy hunting with your wagon!
FYI...
The 4wd wagon is very difficult to swap and make changes with as it was the only model until recently that came with 4wd at all making parts difficult to come by, and expensive to modify.
FYI...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB »</TD></TR><TR><TD CLASS="quote">with the center console including cup holders and arm rest (neither of which came on any EF model)</TD></TR></TABLE>
Some ef's have an arm rest
FYI...
The 4wd wagon is very difficult to swap and make changes with as it was the only model until recently that came with 4wd at all making parts difficult to come by, and expensive to modify.</TD></TR></TABLE>
Difficult? I'll give you "different"...but not "difficult".
If you want to keep the 4wd, you can put in pretty much any of the D-series motors.
They swap in like any other Civic/CRX. The only difference is in the tranny.
And who is going to modify the actual 4wd system anyway?
FYI...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB »</TD></TR><TR><TD CLASS="quote">Good luck finding pimped wagons. They exist, but they are VERY difficult to find and even fix up if you have the 4wd version. </TD></TR></TABLE>
if thers a will.... theres a way
Maybe I should ask what 'pimped out' means. Me personally, I have avoided the ridiculous mods but lets face it I'm sure theres someone out there rockin a Black Widow kit with no shame, just not me....
EE wagons post
https://honda-tech.com/zero...age=1
not archived either
<U>The new Honda Civic Wagon Webring</U> (5 forums, albeit soon to be reduced, but 5 nonetheless)
http://hondacivicwagon.tribepest.net/
...also soon to be under one url http://www.hondacivicwagon.com
If you are referring to the 84-87 wagons, you can swap the brown top dohc zc.
or turbo it, I never had one but if the opportunity presents itself I may. There are many here who have modded the 84-87 very well here on H-T.
https://honda-tech.com/zerothread?id=1255972
there is a guy in the thread & @ redpepperracing.com who has a turbo 84-87 EW wagon. (sorry but the pics a re down & not my fault
)B swaps are possible also for the 2wd and 4wd ??? haven't seen it
If you are referrring to the 88-91 wagon I'll lift the last response I gave on this thread
https://honda-tech.com/zerothread?id=1340602
Originally Posted by Akiraboy
If you are referrring to the 2wd wagon then you are only limited to what you can afford i.e. a 426 hemi
maybe 2 of em
Since you didn't specify which wagon you have I will assume you have a 2wd civic wagon and not the rt4wd.
D series motors from later models and the jdm market like the dohc zc & sohc zc will swap in easiest
2wd & 4wd
B series motors are a common swap since its ~ swappin into any 4th gen
for 2wd, 4wd ????
H & F series can be done but its alot more difficult judging from whats been posted here on H-T BUT its not impossible. 2wd same as 4th gen swap hint: search 2point2
4wd ??????
K series is the swap of choice if you're bankin, this swap may soon replace the b swap at some point since the introduction of so many swap friendly kits. I'm sure more will follow. This one may be the most expensive of all Honda motors currently due to its recent introduction but as more motors become available the prices may lower. Again same as 4th gen installation, search K series. The 2wd is A++ for this swap option but 4wd is definately uncharted territory to my knowledge.
v6 *shrugs* .....
maybe 2 of em
2wd & 4wdB series motors are a common swap since its ~ swappin into any 4th gen
for 2wd, 4wd ????
4wd ??????
v6 *shrugs* .....
...99% of the standard parts do not fit, there are no body kits/mods sold for it, and interior upgrades are virtually impossible without destroying OEM parts
nice modded wagon, these are the NJ guys
The interchange IMO is better than the 1% balance you've implied. The interior is not a complete hack but is a little difficult.... I went to a Teg cluster and a CRX dashboard.
FYI...
be ready to use alta vista/babelfish to translate as well.
I have found quite a bit of information from Japan and Germany.
Use these in different combinations...In the meantime I'm sure there are others who are willing to contribute some more info
AND thanks to Gutterslide, he has done an extensive job archiving alot of the wagon pics, some used throughout this post and others. He is more meticulous about these images than I am. He would be a great reference for those images as well.
OMG these cars are so hot.
i just went to look at one today to buy but they didnt want to budge on the price so i didnt pick it up. it is going for about 3k with 59k miles original miles is what they are saying. its at a dealership. the car runds pretty good. but i dont like that its an automatic. its a 1991 silver.
Anything this old with only 59k is going to command a premium. Do a Carfax and see if there is any indication of odometer rollback...sneaky, underhanded dealers.
There is some bounce in the 88-91 Civics value that isn't reflected in most car valuation sources(Blue book, NADA etc). Good, clean, low mile examples are commanding significantly more then what they are officially worth. If I was in the market, I wouldn't bat an eye at paying $5k for an EF with low miles and mint interior/exterior.
the interior was nice but not perfect. and it was repainted. usually i consider that not perfect. i saw a civic wagon on the civic wagon site and i asked about that car for sale but the person who posted it did not reply back at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax »</TD></TR><TR><TD CLASS="quote">Akiraboy:
for putting this post on the right path...</TD></TR></TABLE>thanks but the guys that deserve the credit are Davens, d357roy, Altoid, Turbowagonman aka Civicwagonman, Yoshi____ , Clsmooth, Gutterslide Shuttlexer, nameless rb 26, vtecvillian, Shaun K, Soyracer, Sanjiyan, Yenpit, Pacifier, T140568, the NJ Wagons, Slopoke <U> damn </U> and a whole bunch more. These are the guys who've done a good bit of work on their wagons & somehow they've never received accreditation for their efforts or at least have never had one central location to showcase all their work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 »</TD></TR><TR><TD CLASS="quote">the interior was nice but not perfect. and it was repainted. usually i consider that not perfect. i saw a civic wagon on the civic wagon site and i asked about that car for sale but the person who posted it did not reply back at all.</TD></TR></TABLE>
which person was that & send me a link to the thread...I'll see if I can find you an answer
Right now there are 3 active boards, & 2 message boards. http://www.hondacivicwagon.com is now a Webring. Its a portal to 5 different wagon message boards. I figured it would be the best way to bring everyone looking for civic wagon information together. We are looking into consolidating 3 of the boards into one main resource but thats another issue...
for putting this post on the right path...</TD></TR></TABLE>thanks but the guys that deserve the credit are Davens, d357roy, Altoid, Turbowagonman aka Civicwagonman, Yoshi____ , Clsmooth, Gutterslide Shuttlexer, nameless rb 26, vtecvillian, Shaun K, Soyracer, Sanjiyan, Yenpit, Pacifier, T140568, the NJ Wagons, Slopoke <U> damn </U> and a whole bunch more. These are the guys who've done a good bit of work on their wagons & somehow they've never received accreditation for their efforts or at least have never had one central location to showcase all their work.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 »</TD></TR><TR><TD CLASS="quote">the interior was nice but not perfect. and it was repainted. usually i consider that not perfect. i saw a civic wagon on the civic wagon site and i asked about that car for sale but the person who posted it did not reply back at all.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akiraboy »</TD></TR><TR><TD CLASS="quote">thanks but the guys that deserve the credit are Davens, d357roy, Altoid, Turbowagonman aka Civicwagonman, Yoshi____ , Clsmooth, Gutterslide Shuttlexer, nameless rb 26, vtecvillian, Shaun K, Soyracer, Sanjiyan, Yenpit, Pacifier, T140568, the NJ Wagons, Slopoke <U> damn </U> and a whole bunch more. These are the guys who've done a good bit of work on their wagons & somehow they've never received accreditation for their efforts or at least have never had one central location to showcase all their work.
haha...quit being so modest man!
thx again for the props but people are gonna start talkin....
jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by douglaslovin »</TD></TR><TR><TD CLASS="quote">what year is this
I can only tell you it's a 88-91 wagon, belongs to one of the NJ guys
thanks. could you list up all the boards here so i can jump to them and check them out.
also here is the link to the civic i was looking at. i highly doubt the car is still for sale now.
http://p196.ezboard.com/fhonda...topic
can you get me a phone number to get in contact with the seller?
