FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805
Old Aug 19, 2005 | 03:51 PM
HGZ's Avatar
HGZ
Default FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805
I have decided to take offers instead of setting my own prices. If anyone wants to make me an offer on anything you see, let me know. As of right now, I will not ship these. You must come pick the parts up yourself. If you really need something shipped, I might do it if the price is right and the part isn't too big.
1.) 88-91 Civic/CRX Honda Moonroof Wind Deflector - small scratches. brackets not included. i had to fabricate my own. not hard at all. you may be able to use the ones i made if i can find them.
2.) 88-91 Civic HB trunk taillight covers - fair condition.
3.) 90-91 OEM Civic HB corners - fair condition. good sized scratch on passenger lens.
4.) 88-91 Civic HB rear trunk shock tower covers - fair condition.
5.) D16 intake manifold - <FONT COLOR="red">PENDING</FONT> will need to be cleaned.
6.) 88-91 Civic/CRX(Maybe) steering column cover - <FONT COLOR="red">SOLD</FONT>
7.) 88-91 Civic HB rear wiper motor - good condition, worked perfectly before it was pulled.
8.) 88-91 Civic/CRX something or other - <FONT COLOR="red">PENDING</FONT> sorry i'm having a brain fart. i forgot what this was called and what its for. i know someone out there might be able to use it. good condition, worked perfectly before it was pulled.
9.) 88-91 Civic/CRX(Maybe) under dash fuse panel - good condition, worked perfectly before it was pulled. some fuses/relays may be missing.
10.) 88-91 Civic HB ashtray assembly and coin holder - good condition.
11.) 88-91 Civic/CRX(Maybe) under-hood fuse panel - good condition. some fuses may be missing.
12.) Autozone Reman. Alternator - only used in the Civic for about 5 months.
13.) 90-91 Civic HB Gauge Cover - fair condition. has velcro tape that was used with a dash cover and a white honda emblem super glued to the top. also has holes drilled on the right side where i had a shift light mounted.
14.) OEM D16 Header - fair condition.
15.) 88-91 OEM Civic/CRX Four-Spoke Steering Wheel w/Flat Black Painted "H" Logo - <FONT COLOR="red">SOLD</FONT>
16.) 88-91 OEM Civic/CRX(Maybe) Steering Rack with Ignition and key - <FONT COLOR="red">SOLD</FONT>
17.) 88-91 Aftermarket Civic HB Center Taillight Lens - lens used to be a clear lens, but i painted it transparent red. JDM lens has been <FONT COLOR="red">SOLD</FONT>
18.) Set of 12 Lugnuts with Plastic Rings to hold hubcaps in place - good condition. i bought all of these new from the dealership for around $35. barely used.
19.) 88-91 OEM Civic/CRX(Maybe) Washer Fluid Reservoir. - good condition. pumps are still attached. hoses not included.
20.) OEM D16 Fuel Rail - <FONT COLOR="red">PENDING</FONT> good condition.
21.) Spare Tire Screw Down - good condition. i have also have the actual spare tire as well which is also in good condition (not pictured).
22.) 88-91 Civic HB/CRX(Maybe) passenger side ECU cover - good condition.
23.) 88-91 OEM USDM CivicHB/CRX(maybe) Driver Side Rear View Mirror - good condition. non-power. has blind-spot circle mirror still stuck to it.
24.) Another 88-91 Civic/CRX Ashtray - good condition.
25.) 94-97 OEM Accord Rear Side Marker Light Assemblies - good condition. used these on my rear Civic HB bumper.
26.) 88-91 Civic/CRX(Maybe) Sun Visors - fair condition.
27.) OEM D16 Spark Plug Wires - good condition. worked perfectly before they were pulled.
28.) 90-91 Civic HB Hazard Switch and OEM Hood Washer Nozzles - good condition. worked perfectly before pulled.
29.) 88-91 Civic/CRX(maybe) Climate Control - <FONT COLOR="red">PENDING</FONT> good condition/cables not included.
30.) 88-91 Civic/CRX(maybe) Handle Bars - good condition.
(above) 90-91 Civic HB/CRX(Maybe) 3A Racing Exhaust - bought from eBay. might have been for a sedan, because I had to take it to a shop to get the tip shortened because it stuck WAY OUT. dent on the bottom and top.
(above) 94-01 Integra Muffler Can with Titanium Blazed Tip - rear-section only with flange. nice deep sound. i was very pleased with this muffler but had to take it off because i'm scared of being pulled over at the moment. silencer included, but it sounds raspy with it screwed in. very good condition. bolts right on.
<FONT SIZE="4">not pictured:</FONT>
90-91 Civic HB Moonroof Assembly - pulled from my 90 Si. one of the tabs holding the glass to the track has broken off, so this may be un-useable now, but i'm sure someone could use the glass itself. drain hoses/moonroof switch not included. i'm not sure if this will fit CRXs. may fit 88-89 Civic HB.
88-91 Civic HB Rear Lower Seat Cushion - small cig burn on the driver side seat.
90-91 Civic HB JDM STANLEY Clear Corners - bought used from Autosonic in Arcadia but never had the chance to put them on.
90-91 Civic HB Interior Door Panel Driver Side - has a small screw in it that kept a cup holder in place.
18" Konig Monsoon Knockoffs (no rivets) 4x100 pattern - bought these from a friend but never had money for new tires. currently they still have his old worn down no good tires on them. none of the tires are useful. 11 lugs plus key included.
i will try and get pictures up of the rims, JDM corners, rear seat and door panel soon.
make an offer on anything you might need. hell i may even give it to you for free.
Modified by HGZ. at 4:00 PM 9/3/2005
Old Aug 20, 2005 | 02:31 PM
HGZ's Avatar
HGZ
Default Re: FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805 (HGZ.)
^bump for new pictures added.
Old Aug 20, 2005 | 05:00 PM
884drb16's Avatar
I would like to know how much for #'s 6, 15, 16 PM me a price thnx
Old Aug 25, 2005 | 01:46 PM
turboLSef's Avatar
bump and pmed
Old Aug 25, 2005 | 05:33 PM
884drb16's Avatar
Default Re: FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805 (884drb16)
where ARE YOU?????
Old Aug 25, 2005 | 06:19 PM
silentdork818's Avatar
5, 8, 20, and 29 for me. Ill take the rear section too. How much? And where in 805?
Old Aug 26, 2005 | 02:33 PM
HGZ's Avatar
HGZ
Default Re: FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805 (ef four door)
thanks for checkin out the stuff, guys.. pm'd all three of you
Old Aug 26, 2005 | 07:15 PM
migizzel's Avatar
pm you about the moon roof let me know
Old Nov 5, 2005 | 11:48 PM
xHONORTHEBRANDx's Avatar
Bump for this jigga!
Old Nov 6, 2005 | 11:09 AM
ImXposed's Avatar
Needs $$ for a Hooker
Default Re: FS: 90-91 EF Civic HB Parts/Some 94-01 Integra Parts - Ventura County 805 (xHONORTHEBRANDxDB8)
how much for the integra muffler?
HGZ
Sep 18, 2008 03:21 PM
bigmill_11
May 19, 2004 04:39 AM
