Milling dohc zc head ?
Old Aug 19, 2005 | 02:09 PM
Hollywoood's Avatar
Default Milling dohc zc head ?
How much can I safely take off my head on my dohc zc to up the compression, I have read .8mm for 10:1, and 1.4mm for 10.6:1. I was hoping someone can verify this and let me know if it is safe!
Thanks!!
Ryan
Old Aug 19, 2005 | 02:32 PM
Kryogen's Avatar
not sure what is safe but your gonna need Adj. cam gears or your timing will be fubar'ed.
Old Aug 19, 2005 | 02:34 PM
speedd2286's Avatar
Default Re: Milling dohc zc head ? (Hollywoood)
bump...im interested too
Old Aug 19, 2005 | 02:41 PM
dr_latino999's Avatar
Clay the stock motor and see how much clearance you have now, then mill away with your new found knowledge. I would advise stronger valve springs just in case one of the valves wants to get personal with a piston relief.
Old Aug 19, 2005 | 07:09 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hollywoood &raquo;</TD></TR><TR><TD CLASS="quote">How much can I safely take off my head on my dohc zc to up the compression, I have read .8mm for 10:1, and 1.4mm for 10.6:1. I was hoping someone can verify this and let me know if it is safe!
Thanks!!
Ryan</TD></TR></TABLE>
we took .040" off the block and .080" off the head - with Crespo stage 4 cams and 88-89 Integra head gasket it still has plenty of clearance - compression ended up about 14:1
Old Aug 19, 2005 | 09:25 PM
Newark Built's Avatar
* B A N N E D *
Default Re: Milling dohc zc head ? (jlicrx)
I run a machine shop with my pops...
Maybe you can get the shop to grind off what you want on a surface grinder.
The finish will be ALOT better then milling it, Parts I do on my Brown and Sharpe grinder basically come out looking like a mirror...should help the gasket seal better, dont know if its been done cuz everyone talks about milling it.
For an example of surface grinding....
All flat surfaces where surface ground...The outside diameter i did on a OD Grinder...63 Rockwell hardness was a bitch to grind! The pockets where done on my HAAS VF4 CNC
BTW...These parts are for a 1000 Ton press...kind of like tooling for it
3 parts come together to make the bottom and 3 come together and make the top...then the two sections come together and each flat surface makes up one side of a cube when everythings together.
I know its some complicated ish...
FYI These presses are used to crush rocks and stuff for scientific research...I know one guy in Sweden uses heating elements and makes synthetic diamonds with it
Old Aug 19, 2005 | 09:37 PM
boosted_hatch_216's Avatar
Default Re: Milling dohc zc head ? (Newark Built Kandy SiC-RX)
youd probably be safer welding the CC's, you wont have to worry about claying the motor and you wont have to worry about upgrading cams.
Old Aug 19, 2005 | 11:22 PM
Twilight's Avatar
Default Re: Milling dohc zc head ? (boosted_hatch_216)
I have done 1.1mm from the surface, and it worked very good.
Just set the timing little bit. And it would be best if you have camgears.
Old Aug 20, 2005 | 07:54 AM
2point2's Avatar
surface grinding is very clean and extreemly flat. I used it to make a small die recently. but i've never seen one do aluminum? do you just change the wheel?
Old Aug 20, 2005 | 08:40 AM
* B A N N E D *
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">surface grinding is very clean and extreemly flat. I used it to make a small die recently. but i've never seen one do aluminum? do you just change the wheel?</TD></TR></TABLE>
Nah i use the same wheel I use on everything else i grind (420 SST, H13, S7,P20),
You just have to be light on the cuts and use alot of water...A little trick of the trade...take a piece of wax ( even candle wax) and sort of coat the wheel with it after you dress the wheel...The wax fills in the pores of the wheel so that the aluminum dosent gunk it up.
Old Aug 20, 2005 | 09:18 AM
2point2's Avatar
Default Re: (Newark Built Kandy SiC-RX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newark Built Kandy SiC-RX &raquo;</TD></TR><TR><TD CLASS="quote">Nah i use the same wheel I use on everything else i grind (420 SST, H13, S7,P20),
You just have to be light on the cuts and use alot of water...A little trick of the trade...take a piece of wax ( even candle wax) and sort of coat the wheel with it after you dress the wheel...The wax fills in the pores of the wheel so that the aluminum dosent gunk it up. </TD></TR></TABLE>
builtsinglecam
10
Sep 21, 2009 09:43 AM
cdescoteaux
Jan 29, 2007 12:13 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
redzcstandardhatch
14
Apr 30, 2003 11:42 AM
