b16 in Sand rail
Old Aug 19, 2005 | 01:50 PM
spoonInspired's Avatar
Default b16 in Sand rail
say i wanted to throw a b16 in a rail and had it all bolted up. what could i strip from the wire harness , and what has to stay? is it possible to modify the harness to simplify it to where i can run it in the sand rail... if anyone has any ideas let me know thanks....
heres a pic of what the sand rail looks like, the customer is think'n about either a b16 or gsr on the back...
Old Aug 19, 2005 | 03:19 PM
Dancing is Forbidden's Avatar
Default Re: b16 in Sand rail (SpoonHatch94cx)
http://www.locashracing.com Check them out. Joe has a race harness which is straight from the engine to the ecu.
EDIT: ****, Just noticed your local to him. go visit him at HASport and talk to him about getting one.
Old Aug 19, 2005 | 05:53 PM
mrbsponge's Avatar
contact member BLOWN90HATCH he did some sand rail harness work a few weeks back with honda motors
Old Aug 21, 2005 | 06:32 PM
locash's Avatar
I've done plenty of sandrail harnesses, so it's no problem. Also, I start with a brand new harness, not a used one.
Old Aug 21, 2005 | 10:14 PM
j87w's Avatar
Default Re: b16 in Sand rail (locash)
Not to get off topic, but what tranny are you using? The B series motors spin "backwards" I thought so it wouldnt work with a like a Type 3 VW transmission. I have a sandrail and was going to do the exact same thing.
Old Aug 23, 2005 | 05:55 PM
Blown90hatcH's Avatar
Looks good man. I have been doing sandrail harnesses for a while. I use only MIL spec heat shrink, wire and processes. Let me know if you are interested.
Jason
http://www.JKobd.com
Old Aug 30, 2005 | 06:28 AM
JonnyCoupe's Avatar
Default Re: b16 in Sand rail (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">Not to get off topic, but what tranny are you using? The B series motors spin "backwards" I thought so it wouldnt work with a like a Type 3 VW transmission. I have a sandrail and was going to do the exact same thing.</TD></TR></TABLE>
Its mid engine, im sure he'll just use a GSR tranny with a GSR engine The 'honda spins backwards' line is only an issue for Front engine rear drive cars.
Old Mar 5, 2006 | 11:47 AM
crxh22project's Avatar
Default Re: b16 in Sand rail (JonnyCoupe)
what about the shift linkage anyone got info on it
Old Mar 5, 2006 | 12:10 PM
raiden571's Avatar
i would personally go with a b18c1. or b18b. hes gonna want more torque i would think for going thru sand, then again that think probably doesnt way nearly as much as a car
Old Mar 5, 2006 | 12:26 PM
hondaZvic's Avatar
Default Re: (raiden571)
go h22.
Old Mar 6, 2006 | 09:05 PM
T
Default Re: (hondaZvic)
yeah H22 or K20 would be the ****
Old Mar 6, 2006 | 09:47 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">go h22. </TD></TR></TABLE>
This would definitely be the way to go. Not only does H-series have more power and torque than B-series. It is also MUCH cheaper. You can get a complete changeover for $2000 from an engine importer. And given the fact that swapping H-series into a sandrail is probably not going to be any harder than B-series, why not?
Old Mar 6, 2006 | 10:04 PM
highendmike's Avatar
Multiple Accounts, banned multiple times
Default Re: (StorminMatt)
Contact HOOKUPS on this site he has a b20/V-tech turbo on his rail.
Mike
felipe69
Feb 3, 2008 09:00 PM
streetracerof06
Dec 8, 2005 05:54 PM
spoonInspired
11
Aug 20, 2005 10:04 PM
CRseXy
Jul 4, 2005 08:49 AM
IVI
Mar 7, 2005 05:33 PM
