shifter play...help
Old Aug 19, 2005 | 12:24 PM
sycamore
Guest
Posts: n/a
Default shifter play...help
so i have a lot of play in the shifter. when it is in first i can move the shiter left and right like a mother and in nuteral it is really hard to find gears. is that my shift fork of just my keeper is to small.
Old Aug 19, 2005 | 12:37 PM
sam385's Avatar
Default Re: shifter play...help (sycamore)
there are several rings and bushings that could be worn out and several bolts that could be loose in the shifter linkage. could be the lever ball seat is funky as well.
check the gearshift linkage and associated bolts, washers, bushings, etc for excessive play.
Old Aug 19, 2005 | 12:59 PM
donuttes's Avatar
i would order a shifter bushing kit from energy for like 15 dollars...makes the shifts 20x cleaner
Old Aug 19, 2005 | 01:08 PM
gnar kill's Avatar
Default Re: (donuttes)
all stock efs have horrible play with the stock shifter bushings replace them with neuspeed or energy urethane bushings.......actually I have an extra set I could send ya hit me up with a pm if you are interested
Old Aug 19, 2005 | 01:54 PM
vegaskurt's Avatar
Default Re: (gnar kill)
Go under the car and find where the shifter meets the selector on the tranny. If you can move the shifter rod without the selector moving then the linkage or the bitch pin is worn.
Old Aug 19, 2005 | 03:35 PM
sycamore
Guest
Posts: n/a
cool i going to give all things a try im missing gears like a mother. it is impossable to fine 3 and 5..
Tampa Native
Feb 21, 2008 01:04 AM
gameknb
Jun 11, 2005 07:32 AM
BAZ
Jul 29, 2003 09:29 PM
Regular Series
Sep 14, 2002 10:41 AM
