Are CRX HF motors interference motors?
Belt broke on my HF putting in a ZC but are they interference motors just wanted to know for ***** and giggles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen »</TD></TR><TR><TD CLASS="quote">yeah there interference, but theres some factors involved to whether they will destroy themselves when a Tbelt snaps.</TD></TR></TABLE>
THE factor that determines whether anything will be broken is luck. Specifically, it is possible for the cam(s) to come to rest in such a position that none of the valves are sufficiently open for the pistons to hit them. In such a case, no damage would be done. Of course, if you just want to put on a timing belt to get the engine running for the time being, you might try doing a leak down test. This will tell you if you have bent valves. And it can spare you the expense of buying a new belt for a bad motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen »</TD></TR><TR><TD CLASS="quote">but just because the belt broke does not necesarily mean you broke anything, Ive broke a timing belt on my dohc zc and it didnt bend or bust anything.</TD></TR></TABLE>
my sister blew the belt on a SOHC ZC - started right up with a new belt.
crxzcracer
Mar 29, 2004 05:23 AM
vtec_head
Feb 20, 2003 06:20 AM
