90 HF Tranny into my 89 Civic sedan. Will it fit?
Old Aug 19, 2005 | 06:53 AM
SiMateoAko's Avatar
Default 90 HF Tranny into my 89 Civic sedan. Will it fit?
I want to eventually install a 1990 CRX HF tranny into my 1989 Civic Sedan.
I'm pretty sure I'll have to replace the clutch disk b/c they come from different years for it to work.
If i replace the clutch disk and bolt it in, will it just be plug and play? Will it work with my axles?
Old Aug 19, 2005 | 07:06 AM
b18_crx's Avatar
Default Re: 90 HF Tranny into my 89 Civic sedan. Will it fit? (SiMateoAko)
i beleive that if you do that you will have to change hubs................hx axles i beleive are smaller some one correct me if wrong
Old Aug 19, 2005 | 07:09 AM
Jonathan_ED3's Avatar
I thought only the STD had smaller axles?
SiMateoAko's Avatar
Default Re: 90 HF Tranny into my 89 Civic sedan. Will it fit? (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">i beleive that if you do that you will have to change hubs................hx axles i beleive are smaller some one correct me if wrong</TD></TR></TABLE>
I'm talking about the CRX HF, not the Civic HX
Old Aug 19, 2005 | 07:14 AM
jlicrx's Avatar
it will bolt right in - use your axles, as all L3 transmissions (except ZC) have the same diameter and number of splines where the axles fit into the differential - axles are only different at the hub end on CRX HF and Civic STD models - will work with clutch you have - as long as transmission isn't 88, it will work with any 89 and up clutch
Old Aug 19, 2005 | 07:20 AM
SiMateoAko's Avatar
Default Re: 90 HF Tranny into my 89 Civic sedan. Will it fit? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">it will bolt right in - use your axles, as all L3 transmissions (except ZC) have the same diameter and number of splines where the axles fit into the differential - axles are only different at the hub end on CRX HF and Civic STD models - will work with clutch you have - as long as transmission isn't 88, it will work with any 89 and up clutch</TD></TR></TABLE>
Maraming salamat, muchas gracias, and thank you
Old Aug 19, 2005 | 08:32 AM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko &raquo;</TD></TR><TR><TD CLASS="quote">
Maraming salamat, muchas gracias, and thank you </TD></TR></TABLE>
I ASSUMED YOU WERE DOING ENTIRE HF SWAP..............like knuckle hub and all that stuff..........sorry
Old Aug 19, 2005 | 01:33 PM
AZTEKEF9's Avatar
what he said...
88 trannies have 21 spline..
89 and up are 20 splines..
u can install any 89-91 into any d series motor...u would only have to match the flywheel with the clutch...
Old Aug 19, 2005 | 01:37 PM
SiMateoAko's Avatar
Default Re: 90 HF Tranny into my 89 Civic sedan. Will it fit? (AZTEKEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">what he said...
u can install any 89-91 into any d series motor...u would only have to match the flywheel with the clutch...</TD></TR></TABLE>
Sweet. IN that case I'm glad I got the 90 instead of the 88
firejackal
Jul 12, 2012 10:11 AM
onemore
Jan 9, 2008 03:51 PM
SnakeBait
Jun 13, 2007 10:20 PM
classciv
Jan 23, 2007 08:17 PM
Silent Knight
Jul 19, 2005 12:20 PM
