will 88 crx fenders fit 91 corner lens
Old Aug 19, 2005 | 02:21 AM
slammedef8's Avatar
Default will 88 crx fenders fit 91 corner lens
i have a 88 crx and my 91 jdm corners wont fit ... any help
Old Aug 19, 2005 | 04:07 AM
steronz's Avatar
ok, here's what you do.
1) hack all the mounting brackets off your 90-91 corners... they just stick out and get in the way.
2) go the the hardware store and buy some 1" by 1/8" aluminum strips. cut two pieces about 8 inches in length.
3) drill a hole in one end of each strip. that end will bolt to the bracket that holds the front of the fenders to the car.
4) twist and contort the strip until the free end makes a nice flat mounting surface for the corner light wherever you want to mount it.
5) rough up the end of the strip and the flat surface on the corner light.
6) take the bumper off and get some masking tape. make sure everything's lined up exactly right, then epoxy the hell out of the light and slap it to the strip. tape it in place until it's tacky and will hold on its own. remove the newly epoxied parts and epoxy them again... slather them with that ****.
bolt everything back up and you're good to go. the alternative is getting new headlights and new fenders. i went with this route. it gives you a lot more flexibility when lining everything up, too, and i doubt they'll fall off anytime soon.
no pics of my brackets, but here's a pick installed... 90-91 corners on my 89 crx with stock fenders and headlights:
Old Aug 19, 2005 | 07:36 AM
Newark Built's Avatar
* B A N N E D *
Default Re: (steronz)
90-91 corners fit on my 88 fenders
http://www.sounddomain.com/mem...l.jpg
Old Aug 19, 2005 | 09:58 AM
Kryogen's Avatar
they will fit the fenders, notice how 90-91 fenders have the holes for the screws but no plastic clips in the holes, the fenders are identical.
I believe its the headlight buckets that are different.
get 90-91 headlight buckets Im about 99% positive thats where the corners screw to.
Old Aug 19, 2005 | 11:58 AM
slammedef8's Avatar
Default Re: will 88 crx fenders fit 91 corner lens (slammedef8)
THANKS
Old Aug 19, 2005 | 12:15 PM
88 rex's Avatar
Default Re: (Kryogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">they will fit the fenders, notice how 90-91 fenders have the holes for the screws but no plastic clips in the holes, the fenders are identical.
Did this the other day, just transfered the plastic clips from 88 fender to the fender from the 91 and i could use my 88 corner lights. The fenders are identical.
Old Aug 19, 2005 | 12:31 PM
* B A N N E D *
Default Re: (88 rex)
get 90-91 headlight buckets Im about 99% positive thats where the corners screw to.</TD></TR></TABLE>
Old Aug 19, 2005 | 04:21 PM
V8K1LLER's Avatar
Default Re: (Newark Built Kandy SiC-RX)
Old Aug 19, 2005 | 08:06 PM
MulletManRockStar's Avatar
The correct way is to use 90-91 Headlight buckets/frame. Use 90-91 clips on the fenders. Thats correct way to do it and get it to line up as perfect as possible.
mruneek
Apr 6, 2011 12:48 PM
boostedDA
30
Mar 16, 2010 10:32 AM
Eli2
44
Apr 4, 2009 08:26 PM
dpfi_1.6EFktr
Sep 20, 2007 12:05 PM
Crimson_Tide
Jul 11, 2005 03:21 PM
