HARD shifting
Old Aug 19, 2005 | 12:02 AM
Alibi86's Avatar
Default HARD shifting
recently ive noticed that when i shift out of park into drive, or anything for that matter, it seems to shift very hard, like, the whole car shakes ALOT. It does not only happen when im parked on a hill, but when i am on flat ground too. Is this a result of my tranny slowly takin a **** on me? or what?
Old Aug 19, 2005 | 04:36 AM
YeuEmMaiMai's Avatar
change tbe fluid and add a can of lube guard made for import transmissions. I have a 1994 LX with 134K and I change the fluid once a year (drive 10K or less every year) and right after I change the fluid it works a whole lot better. I got the car in 2000 with 87K on the odo and have only put 47K on it.
Old Aug 19, 2005 | 09:04 AM
RiceRocketDave's Avatar
Default Re: (YeuEmMaiMai)
It could be a motor mount as well.
Old Aug 19, 2005 | 09:13 AM
Default Re: (ricerocketdave)
May be a mount. most likely the front one and if it has been a while since you noticed it, the rear one as well
Old Aug 19, 2005 | 11:31 AM
Alibi86's Avatar
is it common though for it to only shift hard out of park and no other gear? Do you reccomend changing the fluid or jus re-plenishing it?
Old Aug 19, 2005 | 02:09 PM
Default Re: (Alibi86)
Since you had the mounts inspected, I would change the fluid (drain and fill) and add a can of lube guard.
If your mounts go out it will cause the car to appear to shift hard as the engine slamms against the mount but you may not notice it once the engine and tranny are in gear since the front mount has already got pressure on it.
I would let the car idle for 1 min before shifting out of gear and see if that helps
Old Aug 19, 2005 | 10:29 PM
CB7VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alibi86 &raquo;</TD></TR><TR><TD CLASS="quote">Do you reccomend changing the fluid or jus re-plenishing it?</TD></TR></TABLE>
Replenishing is never really a good idea with any fluid for any car, unless you burn a quart of engine oil a month or or are nursing a slow leak or something.
Old Aug 19, 2005 | 10:49 PM
deserthonda's Avatar
Default Re: HARD shifting (Alibi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alibi86 &raquo;</TD></TR><TR><TD CLASS="quote">recently ive noticed that when i shift out of park into drive, or anything for that matter, it seems to shift very hard, like, the whole car shakes ALOT. It does not only happen when im parked on a hill, but when i am on flat ground too. Is this a result of my tranny slowly takin a **** on me? or what?</TD></TR></TABLE>
how high is the idle set at??? if too high it will make tranny slam when changing gears ........broken mounts ??
Old Aug 20, 2005 | 10:57 AM
Alibi86's Avatar
No, i dont think its the idle. It actually idles pretty low, a little under 1k, or exactly at 1k
Old Aug 23, 2005 | 06:31 PM
CB7VTEC's Avatar
1k is too high if the car is fully warmed up, 700 to 750 is about right
Old Aug 23, 2005 | 06:34 PM
Stealthman80's Avatar
Default Re: (CB7VTEC)
how do you know if thew mounts are broken?
Old Aug 23, 2005 | 10:33 PM
CB7VTEC's Avatar
Default Re: (Stealthman80)
With e-brake on and brake pedal depressed have someone inside the car shift from park to reverse, reverse to park a few times and look for abnormal engine movement or noises. Naturally there will always be some, but if it seems a little much, break out the flashlight and inspect visually for tears or cracks in the mounts. Start with the front and rear mounts, they take the most abuse.
joshsayswhatt
Honda Civic (2006 - 2015)
21
Jan 11, 2011 09:53 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
Beau Gotti
Jun 20, 2005 09:34 PM
pr0gress
17
Apr 5, 2005 05:12 PM
civic_speed99
Jan 20, 2005 06:39 PM
