wiring harness question: si motor into dx
Old Feb 23, 2002 | 02:52 PM
Chris_'s Avatar
Default wiring harness question: si motor into dx
putting a 91 CRX Si motor into an 89 DX. I have a stock Si wiring harness.
Do I need to replace the part of the wiring harness that goes from the ecu to the fuse box? Or can I just replace all of the wiring after the fuse box?
Old Feb 23, 2002 | 03:09 PM
Loaded Butane's Avatar
Default Re: wiring harness question: si motor into dx (crxconnection)
I just put a ZC into my DX and the only parts off of the Si harness I used were the TPS wires, resistor box, and fuel injector wires. The rest you can just use your DX harness.
Old Feb 23, 2002 | 05:16 PM
Blown90hatcH's Avatar
The wiring harnesses are different: 88, 89, 90-91 only.
Jason
Old Feb 23, 2002 | 05:21 PM
ViperRedCRX's Avatar
Default Re: wiring harness question: si motor into dx (Blown90hatcH)
you have to run 4 wires from the ecu to the engine bay(2 for the injectors, and 2 for the distributor), and then convert the dx to an si...the si won't plug in to the dx main harness
Old Feb 23, 2002 | 05:44 PM
Chris_'s Avatar
Default Re: wiring harness question: si motor into dx (d16crxdxr)
I was under the assumption that you could just take out the dx wiring harness (from the fuse box to the engine) and completely replace it with the si wiring harness. Guess not.
So my best bet would be to use my stock dx wiring harness and add the four wires that go from the ecu to various parts of the engine (tps, fuel injectors, etc)?
Thanks for the help.
Old Feb 23, 2002 | 07:10 PM
Yeah, just convert the harness to SI. That is the easiest. I have all the sensor plugs if you want to do it.
JAson
entoy
Aug 18, 2013 04:36 PM
thegreatwhitehope
Apr 5, 2004 08:34 AM
sporty240
Nov 18, 2003 06:13 PM
qcoffey
Jun 29, 2003 07:18 PM
