91 hatch b16a problems Can someone help?
Old Aug 18, 2005 | 10:04 PM
PimpinAintEZ's Avatar
Default 91 hatch b16a problems Can someone help?
ok, its a 91 civic hatch, its got a b16a in it, every once in awhile if im just driving normal not trying to accelrating to fsat it seems like it is just starving of fuel or something bogs down and dont wanna go no where, if you let of the gas and then give it gas again its just fine, or it you go 100% throtle its fine, thought it was the fuel pump put a walbro 255 in, put new fuel filter, plugs wire whole new cap.... any one got any ideas please help. Thanks
Old Aug 18, 2005 | 10:12 PM
InJ3cted's Avatar
Default Re: 91 hatch b16a problems Can someone help? (PimpinAintEZ)
what ecu?
Old Aug 18, 2005 | 11:09 PM
Default Re: 91 hatch b16a problems Can someone help? (InJ3cted)
its a stock ecu i thought but stock it wasnt fuel injected so therefore it must at least have a si ecu, right? ill have to look its got the vafc runnin the vtec so the ecu is from a non vtec car (i would think) ill look go check in the morning and see what ecu it really is...
Old Aug 19, 2005 | 01:48 AM
michael O's Avatar
The ecu could definately be the problem. To run your car correctly you should either get the correct ecu I'm guessing pr3 or pw0 or else get someone to chip your ecu with a b16a map and keep using the vafc.
Old Aug 19, 2005 | 08:17 AM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PimpinAintEZ &raquo;</TD></TR><TR><TD CLASS="quote">its a stock ecu i thought but stock it wasnt fuel injected so therefore it must at least have a si ecu, right? ill have to look its got the vafc runnin the vtec so the ecu is from a non vtec car (i would think) ill look go check in the morning and see what ecu it really is... </TD></TR></TABLE>
im assuming you have pm6 ecu? upgrade that **** man either pr3 or pw0.... a whole lot better fuel maps that are meant for vtec
Old Aug 19, 2005 | 08:37 AM
chadmasterc's Avatar
If you are running a obd0 pwo or pr3 ecu with two 02 sensors you probably have them backwards. you can either switch the wires at the ecu or on the header itself.
Old Aug 19, 2005 | 09:38 AM
raymas8's Avatar
Default Re: 91 hatch b16a problems Can someone help? (chadmasterc)
i got an extra pr3 for sale.. hit me up
Old Aug 24, 2005 | 07:36 PM
i found out what ecu was in the car it was a pw0, so i swaped it out w/ my friends pw0 whcih is chipped, car was alot faster but didnt fix the problem.....any one got any other ideas? when i mounted the new fuel pump could i have mounted it wrong and its no sucking fuel and some points? just an idea...
speedsk899
Jun 13, 2014 05:07 AM
cjwarren4dcivic
Feb 15, 2006 11:55 PM
B18aTegra
Oct 15, 2003 04:57 PM
