new valvetrain. BC3+ wanted
Old Aug 18, 2005 | 09:35 PM
ITRnorway's Avatar
Default new valvetrain. BC3+ wanted
after burning a exhaust valves did idecide to upgrade my OEM valvetrain setup to some omni power valves, springs and retainers with a BC stage III+ cams and cam gear.
i would assume that someone in here have tried it before so i would be intresting to hear about you camgear setup?
Old Aug 18, 2005 | 10:19 PM
an2ny888's Avatar
Default Re: new valvetrain. BC3+ wanted (CRXnorway)
you burned your exhaust valves with the bc3+ cams? what engine do you have? were you using stock itr valvetrain?
Old Aug 18, 2005 | 11:25 PM
strepto's Avatar
Default Re: new valvetrain. BC3+ wanted (an2ny888)
Adjusting the camgears is a normal part of the tuning process. Normally, you'd wanna go with a +/- 0 degree starting point - and let the dyno guide your way.
Old Aug 19, 2005 | 04:26 AM
ITRnorway's Avatar
i have a B18c6 with I/H/E and burned the exhaust valve on my stock valvetrain
Old Aug 22, 2005 | 01:41 PM
rebo0t's Avatar
hm? but i read and was told by everybody if you stay within stock redline it should be fine even with a gsr valvetrain?
Old Aug 25, 2005 | 04:07 AM
ITRnorway's Avatar
Default Re: (rebo0t)
the honda workshop told me it could be wrong valve clerance ond bad maintenance form the last owner
thegatekeeper14
Aug 30, 2010 03:25 PM
GReddy SI
Oct 31, 2009 07:19 PM
Chris F
12
Oct 3, 2006 06:39 AM
choiboiracing
May 15, 2004 03:19 AM
RTW DC2R
May 16, 2002 10:39 PM
