A-spec Racing 32mm sway bar
Old Aug 18, 2005 | 07:24 PM
paRRRker's Avatar
Default A-spec Racing 32mm sway bar
I recently got hooked up with Charleston from A-spec Racing and purchased one of his new 32mm rear sway bars for the type-r or eg civic. It is fully adjustable and has 2 different wall thicknesses you can choose from. I chose the 3mm wall thickness as opposed to the 2.5mm wall thickness for alittle stiffer rear. This bar is on my 2000 py itr H2 race car.
Before I was running the stock 22mm bar and was experiencing a decent amount of understeer thru numerous turns out on track. After I installed this, I found the rear to be somewhat tail happy especially on cold tires. Once the tires are warmed up, I absolutely love the bar and think that it is a great upgrade to any track ITR or maybe even street ITR. I love nothing more than lifting off the gas or simply breathing the car alittle in a turn and having a decent amount of rotation from the rear of the car that really helps with frontend turn-in and grip
Hunter runs the same 32mm bar and rear subframe brace kit on his H1 eg...
Alan (trackrat) also runs the 32mm bar on his H2 itr
Charleston with A-spec gets a from me
Old Aug 18, 2005 | 07:26 PM
.RJ's Avatar
.RJ
Default Re: A-spec Racing 32mm sway bar (paRRRker)
ricer
Old Aug 18, 2005 | 07:51 PM
AussieR's Avatar
Default Re: A-spec Racing 32mm sway bar (.RJ)
That would be WAAAYYY to much bar for the street. You never know when you might have to lift during a corner to avoid <insert obstacle, animal, bad driver> and if the roads are wet, sandy or your just going along at a good rate your screwed.
About 3 months ago i was doing 70kph(about 40mph) in an 80kph zone and as I was coming around a corner a tree fell in the road because gum trees suck and it was windy/rainy as hell. I reacted perfectly but the *** end still came around a bit. The passengers in my car were like "this car usually sucks to be a passenger in but damn it handled that situation nicely." If I had a thicker bar I might not have had enough room to bring the car around.
Old Aug 18, 2005 | 10:53 PM
ninor's Avatar
I agree, street and 32mm bar DO NOT mix... I do not care how good of a driver you are...
Old Aug 18, 2005 | 11:00 PM
92TypeR's Avatar
FSAE
Default Re: (ninor)
Holy *****, I didn't even know they made 32mm sway bars for Hondas. I always thought 26 was it. I can't imagine what the snap lift oversteer would be like though...
Old Aug 19, 2005 | 01:31 AM
DC2IntegraTypeR's Avatar
How is the bar stiffness compared to a Mugen 26mm?
Old Aug 19, 2005 | 02:58 AM
Back in Black's Avatar
Rather OG
Understeer? Hrm...
BTW, I want my number back for '06
Jason-
who doesn't remember feeling much understeer in good ol' #32
Old Aug 19, 2005 | 03:20 AM
.RJ's Avatar
.RJ
Default Re: (ninor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninor &raquo;</TD></TR><TR><TD CLASS="quote">I agree, street and 32mm bar DO NOT mix... I do not care how good of a driver you are...</TD></TR></TABLE>
Its a 32mm hollow bar.... stiffness is equivalent to a 26mm mugen.
Old Aug 19, 2005 | 04:25 AM
Track rat's Avatar
Default Re: (DC2IntegraTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2IntegraTypeR &raquo;</TD></TR><TR><TD CLASS="quote">How is the bar stiffness compared to a Mugen 26mm?</TD></TR></TABLE>
32mm x 2.5mm (hollow)A-spec vs 26mm Mugen.
The soft setting is 5% stiffer than Mugen. The stiff setting is 20% stiffer than Mugen. I'm not sure how the 3mm bar compares.
The A-spec set up is 10 lbs lighter than Mugen 26.
Old Aug 19, 2005 | 04:26 AM
paRRRker's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Back in Black &raquo;</TD></TR><TR><TD CLASS="quote">Understeer? Hrm...
Jason-
who doesn't remember feeling much understeer in good ol' #32</TD></TR></TABLE>
yes...understeer...not much
no on the number ...it might be for sale though lol
maybe you weren't driving the car fast enough
thanks al
Old Aug 19, 2005 | 04:30 AM
paRRRker's Avatar
Default Re: (paRRRker)
also, i'm not necessarily saying itr owners should run it on the street...
personally i would though
I just know there are alot of itr owners that track their car (its intended purpose) in this forum...more here than in the RR forum
Old Aug 19, 2005 | 04:54 AM
Rather OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">maybe you weren't driving the car fast enough
Hrm...
http://www.honda-challenge.com...s.php
Not that I'm picking or anything
Jason-
who couldn't help it, and apologizes.
Old Aug 19, 2005 | 06:28 AM
BudMan's Avatar
Default Re: (Back in Black)
Hrm...
Jason-
who couldn't help it, and apologizes.</TD></TR></TABLE>
Who's the damn franza character...he keeps showing up. Hopefully he's done racing. hehehe
Glad to see you back!
Old Aug 19, 2005 | 08:45 AM
Hooch'n's Avatar
Default Re: (BudMan)
that is a big bar, don't lift Parker!!!!!!!!!!!!!!!
Perfect for working on your Drift'o skills
Old Aug 19, 2005 | 09:10 AM
paRRRker's Avatar
Default Re: (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">that is a big bar, don't lift Parker!!!!!!!!!!!!!!!
Perfect for working on your Drift'o skills </TD></TR></TABLE>
thats not the only big bar i have
Old Aug 19, 2005 | 09:43 AM
Jon V's Avatar
I run the same bar/brace on my Ek...
Street/Track car.
I think I actually had the first test/production setup on my car.
I love it. i used to run it on the streets with my OEM struts and Tien S-tech springs. I have sense upgraded to the Omni race full coilover setup. But the fact hat i ran it on the stock struts and those even crappier springs says a lot for the brace setup. You guys don't have to worry as much with your ITR's but my EK's stock rear subframe would not have liked a 32mm rear sway...
Old Aug 19, 2005 | 11:13 AM
Track rat's Avatar
Hrm...
Jason-
Ouch!
Old Aug 19, 2005 | 12:00 PM
paRRRker's Avatar
Default Re: (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">I run the same bar/brace on my Ek...
Street/Track car.
I love it. i used to run it on the streets with my OEM struts and Tien S-tech springs. I have sense upgraded to the Omni race full coilover setup. But the fact hat i ran it on the stock struts and those even crappier springs says a lot for the brace setup. You guys don't have to worry as much with your ITR's but my EK's stock rear subframe would not have liked a 32mm rear sway... </TD></TR></TABLE>
OMG you ran it on the street...OMG i absolutely cannot believe it!!!
see...not bad on the street
Old Aug 19, 2005 | 12:20 PM
Jon V's Avatar
see...not bad on the street </TD></TR></TABLE>
I daily drove it...
and I will again when I get the swap done...
Old Aug 19, 2005 | 12:28 PM
Rather OG
How good is it against Firebirds? Does it work well?
LMAO...again, I couldn't help it.
Jason-
who hopes Parkay can laugh about that one
Old Aug 19, 2005 | 01:26 PM
Jon V's Avatar
my driveway is a little uneven...
Old Aug 19, 2005 | 01:46 PM
AssPenny's Avatar
Default Re: (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">my driveway is a little uneven...</TD></TR></TABLE> Nice...
Question, how do you adjust the stiffness of the bar?
Old Aug 19, 2005 | 02:03 PM
Hooch'n's Avatar
Default Re: (AssPenny)
u can slide it up and down on the bracket......
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote"> Nice...
Question, how do you adjust the stiffness of the bar?</TD></TR></TABLE>
how far in or out the brackets are slid on the grooves of the actual bar
Old Aug 19, 2005 | 02:24 PM
chad's Avatar
Moderator
Default Re: (ninor)
why NOT?? been driving on jdm 23 mm rear bar with NO FRONT BAR for years....and have yet to spin....
