Bad Fitment VIS hood ............? PICS
My buddies new eg vis hood is like that too, but not that bad. It sits higher than the fender on the driver side corner where the headlamp is. It's not even clost to hitting the rubber bump stop.
they didnt come with the hood, they were on the car bfore i did the 99 conversion.
i also have aftermarket fenders and an aftermarket core support cuz i rear ended someone last winter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilMrTinnie »</TD></TR><TR><TD CLASS="quote">is the front frame bent? if so then your whole front end might be crooked.</TD></TR></TABLE>
i dont know if it is........what are the other possibilities?
all i coudl think of is the frame might be a little bent, or the latchs of the hood could be uneven since from the crash, check those out again, if not then I would put those plastic washers or what those things are on. if all of that doesn't help then i would call VIS. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">well, the hood latch was replaced since the accident. im gona mess around with the hinges to see what happens</TD></TR></TABLE>
I had to adjust the lack on the hood itself, i had to cut it and make it so the hood came down further, and if you look under the hood it says you should use hood pins. i drove to cali with out them and my hood almost flew off cause the bolts slip out of the carbon fiber.... or glue them in!
my friends is like that too...but that was due cause he hit his garage and pushed in his bumper a lil bit...not it doesn't sit right on one side...has your car ever been in a accident?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">they didnt come with the hood, they were on the car bfore i did the 99 conversion.
i also have aftermarket fenders and an aftermarket core support cuz i rear ended someone last winter</TD></TR></TABLE>
I have a suspicion that you fitment problem is at least partially related to this.
i think that the hood is bended but u can fix it by putting pressure on the ok side n force it...or may be the plates that hold the hood or the rubber thingy's...is it a VIS grade A hood becuse those hoods r the best it shoulnt give u any problems....good luck n update
Well I have two VIS hoods one is on a 00 Si and it fits Exactly like the one above in the pictures and I have a VIS hood on my 93 hatch and it has 3 air bubles in it that are pretty big! Im not all that impressed with VIS.
bottom line is
if the OLD OEM hood fit correctly, this one should too. it's an OEM replacement.
it doesn't matter if you did a 99 conversion.
bring it to a body shop and ask them to help you straighten it, if they can't. call VIS
nice car BTW
Modified by Daniel-sanB1 at 11:01 PM 8/18/2005
nice car BTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoehouseworker »</TD></TR><TR><TD CLASS="quote">It looks like the headlight on the right sits lower than the one on the left, that could be part of your problem.</TD></TR></TABLE>
Yes it does. It looks like there is something way wrong with the driver's headlight. It sticks out of the fender and sits lower in the bumper. What ever is causing this is could be why the hood fits like crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Civic_Coupe »</TD></TR><TR><TD CLASS="quote">the OEM hood never fit perfect either. just like the vis one does except the gap was smaller. im just gonna get hood pins.....</TD></TR></TABLE>
theres your answer...
