Ford 68MM T-body upgrade.......
Old Aug 18, 2005 | 03:49 PM
IZsd's Avatar
Default Ford 68MM T-body upgrade.......
This is my latest endeavor... Some say it won't work, others say it will. So, I am going to give it a shot. Free t-body, worth a shot right??
Most say the tp sensor is going to be the biggest area for concern. Both sensors use the same voltage range. I don't see an issue.
I will post back with updates...
Later IZ
funny seeing this on a Honda
Old Aug 18, 2005 | 10:09 PM
mmuller's Avatar
Mad Scientist
Default Re: Ford 68MM T-body upgrade....... (IZsd)
pretty nice; what setup is this going into?
Even if TPS voltages are different, thats no problem, values can be changed on the program
Old Aug 18, 2005 | 11:54 PM
davidluko's Avatar
wow haha that's sweet
Old Aug 19, 2005 | 08:24 AM
d16dcoe45's Avatar
Default Re: (Hatch_R)
That was actually pretty common a number of years ago--to use a large mustang throttlebody (before there were univerally large throttlebodies available) But why did you weld it directly to the manifold? Couldn't you have made an adapter? Not that I don't like the idea--I dig it very much!!
Old Aug 19, 2005 | 08:39 AM
IZsd's Avatar
Default Re: (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">That was actually pretty common a number of years ago--to use a large mustang throttlebody (before there were univerally large throttlebodies available) But why did you weld it directly to the manifold? Couldn't you have made an adapter? Not that I don't like the idea--I dig it very much!! </TD></TR></TABLE>
Its not welded to the manifold, there is an adapter plate on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">pretty nice; what setup is this going into?
Even if TPS voltages are different, thats no problem, values can be changed on the program</TD></TR></TABLE>
It is going on an h22 w/Crower stg2's, a ported/enlarged manifold and some sort of jdm header (all I know is it OLD) VAFC blah...blah..
So pretty much if there is a voltage issue. With what I have, I dont have many options to remedy the problem. Shouldnt be a problem though.....
Thanks for the comments.
Old Aug 19, 2005 | 08:50 AM
MR Dan's Avatar
66.116.69.217
Default Re: (IZsd)
nice welds
Old Aug 19, 2005 | 11:15 PM
mmuller's Avatar
Mad Scientist
Default Re: (IZsd)
would you mind posting exact voltage?
Just for our info.
Old Aug 20, 2005 | 03:18 AM
v4lu3s's Avatar
RTFM
what year is the 68mm TB from or is tha tone bored out? cause it looks identical tot eh 65mm one i have in my ciivc with h22.
Old Aug 20, 2005 | 07:24 AM
d16dcoe45's Avatar
Default Re: (mmuller)
ha ha--didn't look close enough--nice job!!
Old Aug 20, 2005 | 09:15 AM
IZsd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">would you mind posting exact voltage?
Just for our info.
Not at all, Ill gather all the info and post it up..... Hell, if it works I may even post up a little DIY....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">what year is the 68mm TB from or is tha tone bored out? cause it looks identical tot eh 65mm one i have in my ciivc with h22.</TD></TR></TABLE>
Its off of a 97-98 I believe.... I found it in a huge pile of old parts at work. Not saying I am a Fred Sanford, but you got to keep the eyes peeled for cool stuff!! At a dealership its amazing the stuff that gets thrown out.
Old Aug 20, 2005 | 09:35 AM
dumpeDc2's Avatar
I'm a Jackass
grind the ford logo off
Old Aug 20, 2005 | 04:59 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (dumpeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">grind the ford logo off </TD></TR></TABLE>
its on the bottom
Old Aug 20, 2005 | 06:20 PM
IZsd's Avatar
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">
its on the bottom</TD></TR></TABLE>
Thanks....
Old Aug 21, 2005 | 08:06 AM
v4lu3s's Avatar
RTFM
thats cool i just was hoping to find what model and year the 68mm Tb came from sicne the stuff i had based my search off of says that 96-98 was 65mm, 99 was 66.5mm, and 200-2001 were 65mm again.
Old Aug 21, 2005 | 12:13 PM
IZsd's Avatar
Default Re: (v4lu3s)
My guess is that at some point it must have been bored out....
I remember the guys car it came off of was modded pretty extensively. When I found it I held onto it for a while in case he came back for it but never did....Oh well, his loss right.
kantspell
May 30, 2012 03:28 PM
D3U1LT
Feb 10, 2007 02:53 PM
n1div
11
Jan 26, 2005 09:23 PM
Discosteak
19
Feb 10, 2004 05:29 AM
