AUTO B16 INTO 4DR CIVIC
Old Aug 18, 2005 | 03:30 PM
Cm91h22a's Avatar
Default AUTO B16 INTO 4DR CIVIC
Does anyone know if any info exists for this swap. Looking for any links or sites that may help.thanks
Old Aug 18, 2005 | 03:44 PM
FOUR-G's Avatar
Default Re: AUTO B16 INTO 4DR CIVIC (Cm91h22a)
i've been told in the past that the automatic Bseries transmissions are too big and wouldn't fit.
anything's possible though...
Old Aug 18, 2005 | 03:46 PM
dr_latino999's Avatar
Default Re: AUTO B16 INTO 4DR CIVIC (FOUR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOUR-G &raquo;</TD></TR><TR><TD CLASS="quote">i've been told in the past that the automatic Bseries transmissions are too big and wouldn't fit.
anything's possible though...</TD></TR></TABLE> It is, but the frame on that side is going to take a pounding to make it fit, how about an auto ZC or an auto D16Z6 with a little bit of boost?
Old Aug 18, 2005 | 03:59 PM
Cm91h22a's Avatar
i've already got the engine in and all clearance issues worked out(similar to h22 install), i guess i really need info in the wiring side.
Old Aug 18, 2005 | 04:15 PM
Default Re: (Cm91h22a)
Well then, props to you! If it is the OBD-0 ECU being used couldn't you use the stock auto B16 ECU and wire from there the same ?
Old Aug 18, 2005 | 05:58 PM
krazie1's Avatar
BANNED
Default Re: (dr_latino999)
pretty much but if he is still DPFI
then u would have to re wire and if the chasis was a maunal transmission good luck on that one
Old Aug 18, 2005 | 09:08 PM
DA9_DAD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cm91h22a &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if any info exists for this swap. Looking for any links or sites that may help.thanks </TD></TR></TABLE>
I'd like to know how much it cost you for the whole swap. I have a 4dr and would like to do the very same thing. I'm sure that because its an auto that it would be widely available and pissably cheaper, ya?
I'd buy a 5spd but the Mrs. would say otherwise, so Auto here I come.
Old Aug 19, 2005 | 04:28 AM
StorminMatt's Avatar
Default Re: AUTO B16 INTO 4DR CIVIC (EF4_Anthony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF4_Anthony &raquo;</TD></TR><TR><TD CLASS="quote">
I'd buy a 5spd but the Mrs. would say otherwise, so Auto here I come.</TD></TR></TABLE>
Why not just buy another car for yourself? It's not like 1988-1991 shells are expensive. Hell, I just got a 1988 4DR in GREAT shape for $300. That way, you don't have to deal with all the minuses (and there are LOTS) associated with an automatic transmission.
Old Aug 19, 2005 | 10:27 AM
Cm91h22a's Avatar
the wiring on the b16 tranny is different that what would be found on a d16. thats about the only trouble i'm having at this time.
We are trying to finish this swap for a customer that started it at his house and didn't know what he was getting into. so far his bill stands at about $700 for labor (cutting and rewelding motor mounts mostly).
Old Aug 19, 2005 | 07:11 PM
DA9_DAD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cm91h22a &raquo;</TD></TR><TR><TD CLASS="quote">the wiring on the b16 tranny is different that what would be found on a d16. thats about the only trouble i'm having at this time.
We are trying to finish this swap for a customer that started it at his house and didn't know what he was getting into. so far his bill stands at about $700 for labor (cutting and rewelding motor mounts mostly). </TD></TR></TABLE>
I understand that you will have to go from OBD0 to OBD1 for the B16A's..I believe that you can get a wire harness conversion through http://rywire.com that way it's all plug-n-play when they are done with it.
$700 isn't that bad considering a friend of mine nearly spent 3k to drop in a LS in his 97EK.
Good luck mang!
civicb18b
Jan 26, 2024 07:53 AM
RyanA
24
Oct 4, 2012 02:20 PM
Winlight
Apr 1, 2008 05:22 PM
SixguN
May 3, 2005 01:10 PM
cybspur
Sep 14, 2002 06:53 PM
