~4500-VTEC bog and throttle delay
Old Aug 18, 2005 | 01:16 PM
jolt-tsp's Avatar
Default ~4500-VTEC bog and throttle delay
On my wife's RSX-S I'm starting to notice the throttle response is getting worse. Also, from 4500 RPM until vtec kicks in, it seems there is a BIG loss of power. Is this normal? Once it kicks over to VTEC it launches like a rocket, but prior to that, it really seems to be struggling. I don't drive this car very often, so I'm wondering if I'm just not noticing till now, and everyone has that type of response, or if I have a bird stuck in the intake or something.
Old Aug 18, 2005 | 03:40 PM
Tom5's Avatar
Default Re: ~4500-VTEC bog and throttle delay (jolt-tsp)
Could have gotten bad fuel..... first try unplugging the battery for 15 minutes (technical term = reset the ecu).... if that doesnt help its probably the fuel. I'm assuming this is a stock k20a2?
Old Aug 18, 2005 | 03:53 PM
KOREAN's Avatar
Default Re: ~4500-VTEC bog and throttle delay (Tom5)
you probably have a bird stuck in there somewhere.
Old Aug 18, 2005 | 08:35 PM
dc2integra's Avatar
Default Re: ~4500-VTEC bog and throttle delay (korean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean &raquo;</TD></TR><TR><TD CLASS="quote">you probably have a bird stuck in there somewhere.</TD></TR></TABLE>
try putting a new air filter in. considering it is your wife's car it probably has the STOCK intake right? check the air filter. put some octane booster in there if that dont work and try to neutralize your fuel. if that doesnt work then ask a technician. btw. make sure your oil level is good too because vtec is engaged with oil pressure.
Old Aug 19, 2005 | 05:35 AM
jolt-tsp's Avatar
Default Re: ~4500-VTEC bog and throttle delay (dc2integra)
It has an ebay pipe and filter. I'll run through this tank of gas, refill, and see if anything changes. I haven't checked the oil since I noticed it, and it's about due for a change anyway, I'll check that out. I guess I'd better go ahead and check for birds while I'm in there . Thanks guys.
Old Sep 1, 2005 | 01:03 PM
tilt's Avatar
the bog is due to the aftermarket intake and stock vtec crossover. You need to lower the crossover until the transition feels smooth or get some dyno tuning done.
http://www.hondata.com/techk20vtecswitchpoint.html
Old Sep 1, 2005 | 01:41 PM
DC5ITR329's Avatar
Default Re: ~4500-VTEC bog and throttle delay (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">the bog is due to the aftermarket intake and stock vtec crossover. You need to lower the crossover until the transition feels smooth or get some dyno tuning done.
http://www.hondata.com/techk20vtecswitchpoint.html</TD></TR></TABLE>
I have a mugen intake with ECU and my car doesn't bog. do you reg maintences on the car and you should be fine.
Old Sep 1, 2005 | 05:28 PM
blouisgod's Avatar
grab some intake / tb cleaner and go to town. maybe try some injector cleaner while your at it.
Old Sep 2, 2005 | 08:47 AM
jolt-tsp's Avatar
I was thinking that, but didn't figure it was the CAI. Thought it was just tuned from honda to dip before vtec engages.
Old Sep 8, 2005 | 07:43 PM
thielke2004's Avatar
lol, my intake is home made the rubber part from the stock intake and a intake going down wit a cone and i dont baug, u put a breather on the oil thing i hope thats the oil thing? does any one no what it really is ? but wit the home made intake its loud specually when vtec kicks in i like it, lol
Old Sep 9, 2005 | 08:25 AM
jolt-tsp's Avatar
Default Re: ~4500-VTEC bog and throttle delay (thielke2004)
I assume you're talking about the valve cover breather. The best way to do that it to run a catch can. I put a breather filter on my civic, but oil would puddle in it after a while.
Do you have a picture of your setup? it's kinda hard to visualize
poopoohead
Jun 15, 2010 04:45 PM
elektronsi
15
Apr 15, 2010 02:35 PM
Dee A Nine
Jul 22, 2004 05:24 PM
R-Toyz.com
Jan 27, 2004 03:47 AM
hooptie157
Mar 4, 2002 10:38 AM
