replacing headlight bulb
Old Aug 18, 2005 | 12:04 PM
PleaseHelp's Avatar
Default replacing headlight bulb
alright first off i know this may seem like an easy fix, but for some reason i cant seem to do it. i have my owners manuel but the instructions and picture really arent enough for me, im still confused. could someone please elobarate so i can quickily change my headlight bulb and stop being a peddile ?
thank you in advance
Old Aug 18, 2005 | 02:57 PM
deserthonda's Avatar
Default Re: replacing headlight bulb (PleaseHelp)
is this on a 1976 acc hatchback ?? or a 2005 accor d it does make a bit of difference
Old Aug 18, 2005 | 08:20 PM
sauceja's Avatar
Default Re: replacing headlight bulb (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">is this on a 1976 acc hatchback ?? or a 2005 accor d it does make a bit of difference </TD></TR></TABLE>
That doesn't sound very easy to me.
Although my money is on the '03 and up as I have changed at least 5 or 6 already. and for the low/high beam right side you can see them. Low beam left side you have to turn your tire to the right and pull back inner fender. Squeeze you hand/arm (hope they're little) disconnect harness and twist bulb to left and pull out. Be carefull not to touch new bulb as oil will destroy it and Voila. New light bulb.
But this is probably for a 93 camry and now my fingers hurt for nothing.
mark2583
Jan 24, 2010 04:25 PM
Pooby88
Jan 5, 2008 12:44 PM
jfruauff
Oct 25, 2007 02:00 PM
hondaPINK
Honda Civic (2001 - 2005)
14
Aug 9, 2006 10:21 AM
TRAG
Honda Civic (2006 - 2015)
Jul 11, 2006 12:31 PM
