How much compresion can a stock B16 head hold?
Old Aug 18, 2005 | 10:30 AM
cayman_hatch's Avatar
Default How much compresion can a stock B16 head hold?
I was thinking about strocking my b16 with a Toda stroker kit which brings it up to about 11.0:1 with stock head gasket, how much more can it handle?
I'm asking because I want to add a turbo later, I know I can us a low compression
gasket to help but how much more can it handle?
Old Aug 18, 2005 | 10:33 AM
RacerXI's Avatar
Default Re: How much compresion can a stock B16 head hold? (cayman_hatch)
Pass on the stroker kit if you plan on boosting it, unless your pockets are bigger than the grand canyon.
Old Aug 18, 2005 | 10:34 AM
Default Re: How much compresion can a stock B16 head hold? (RacerXI)
Good advice
Old Aug 18, 2005 | 11:22 AM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
how much does the stroking off kit cost?
Old Aug 18, 2005 | 11:30 AM
Default Re: How much compresion can a stock B16 head hold? (2000psi)
2400, go see yourself
http://www.todaracing.com/prod....html
Old Aug 18, 2005 | 11:31 AM
BoOstedEM1's Avatar
Umm no strokin just bore & sleeve your engine...roughly 1200 for stroking
Old Aug 18, 2005 | 12:04 PM
2000psi's Avatar
Default Re: How much compresion can a stock B16 head hold? (BoOstedEM1)
so $2400 and I can be stroking off???
Old Aug 18, 2005 | 12:14 PM
TorganFM.'s Avatar
How much is sleeving and a deckplate? If the cost of those two plus a B18 crank and rods is less than $2400, that's another option.
ntoxicatedtigah
Mar 30, 2009 07:34 PM
EFMAN
Apr 1, 2005 05:13 AM
grenthang
Feb 4, 2004 09:29 PM
grenthang
Feb 4, 2004 07:15 PM
