Couple Of Things After Headgasket Replacement
I noticed two things after I started her up for the first time after the headgasket change was done.
1) Bouncy/Rough Idle
2) Little hint of white smoke coming from behind the exhaust mani. I didn't spot any leaks anywhere over there so I'm thinking its the water that came out of the coolant hole on the block. (flushed everything out with water about 15 min prior to start up and then filled it back up)
civic addict
15
Sep 12, 2010 04:09 AM
Strikerrr
Jul 25, 2005 05:44 PM
