PLEASE HELP---WAT IS BEST OIL FOR MY B16 TURBO???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">olive oil
lol, that's a first.
</TD></TR></TABLE>lol, that's a first.
I use Mobil1 10w30, but i think i need something thicker because it seems to break down pretty fast. Try Amsoil 10w30 synthetic, it's designed for turbo cars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv »</TD></TR><TR><TD CLASS="quote">I use Mobil1 10w30, but i think i need something thicker because it seems to break down pretty fast.</TD></TR></TABLE>
Please explain^^^^^^
NosCivic101,
I reccomend Mobil1 10w30 full synthetic.
NosCivic101,
THATS A GOOD ONE..
I USED THE NEW MOBILE1 10W30.....
</TD></TR></TABLE>THATS A GOOD ONE..
Read the fine print at the bottom of amsoil and see that it says it was tested on non-turbocharged vehicles. I stick with Kendall GT-1 Turbo. 11psi beatin up on the daily.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">olive oil
OLive oil lol,Emmm in the fuel tank or in the engine
</TD></TR></TABLE>OLive oil lol,Emmm in the fuel tank or in the engine
I was using mobile 1 10w-30 full syn. and notice that after a some hard driving my oil pressure will drop below 5 psi at idle. I now run mobile 1 10w-40 full syn and I get about 5-10 psi at idle after same type of driving, So...if you have an oil temp or oil pressure gauge or both you can better monitor you oil and come to your own conclusion about what oil to run. I would stick with synth. as they have been proven to handle higher heat cycles. which brands to use? well thats up to you, but I think whats more important is how often you change your oil. How often you change your oil depends on how hard you drive your car. Also remind yourself that your motor will consume some oil under hard driving and not checking your oil level regularly will cause wear an stress on oil and motor. ****.....I think I just type way to f#%$ much, but I hope I made some sence. Have fun
99delsol
Oct 18, 2006 07:32 AM
95hatchfire
Aug 19, 2004 10:52 AM
