Im trapping 119 with no traction...
What you guys think, ball park I should run on slicks? Im trying to run DR's and ran a 12.496 @119 (not traction and 2.1 60 foot). I'm really trying to break a 11 sec run on the BFG's before I go to full slicks. Possiable? Im making about 400whp at 17-19psi and that's what I ran the 12.4 on. Car was tuned to 21.5 psi on c16 so thats what I'll turn it up to when I start running slicks.
he has an ITR.
Wont work.
Get a little more time under your belt. You should have no probs breaking 11's at all on that set up.
I was trapping 124-125 on a little less HP then you on BFG's
Wont work.
With that MPH I dont think you'll be able to break 11's on radials. Thats around the mph you would have on a high 11 sec. pass on slicks, but good job the car is moving and with more seat time who knows.
Darkness
Darkness
Smarter than you
Work on your driving a bit. 12.4 @ 119 on a radial isn't a bad time, but theres alot left in it. Play with tire pressure, boost level, launch rpm, throttle, how u work the clutch. Do a big burnout on those bfg's. If you could get your 60' down to the 1.9 range then you'd be in pretty good shape.
you should be able to get an 11 out of that mph if you get a dead on launch. i know guys pulling consistant 1.9's on DR's at about the same mph as you, and they are managing to break into the high 11's. but like everything else, its going to take practice/patience (which is sometimes hard to come by
) heat may also be a factor holding you back, good luck though
