Replacing Oil pressure switch D16A6
Did a search could only find info on Vtec applications, and not what I was looking for, any help is appreciated.
Motor: D16A6
Problem: Oil light is on after rebuild
Had the motor rebuilt not long ago, runs strong and has been running great since day 1. Drove from Vancouver BC to California with the oil light on, and I know the pressure is good. I was told by a Honda Mechanic that it happens, and that probably the sending unit needs replacing.
I had thought the sending unit was right beside the oil filter and had the two wires coming from it, am I mistaken? I ordered a replacement from Honda, and found that the one they sent me only has 1 prong for attaching wires. Called back Honda and was told that the “Thermal Sensor” has two prongs, the oil pressure sending unit has 1. Is this correct? If so, where do I find the oil pressure sending unit on the block?
Thanks for any constructive help you can give guys!
Motor: D16A6
If you wanted Ill give you mine. I know they work. ill take them off and ship them to you if youd like. off of my blown D16a6
just have to tell me where they are located. im pulling the motor this weekend. im looking for a zc to swap in so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivic91 »</TD></TR><TR><TD CLASS="quote">
Called back Honda and was told that the “Thermal Sensor” has two prongs, the oil pressure sending unit has 1. Is this correct? If so, where do I find the oil pressure sending unit on the block?</TD></TR></TABLE>
Yes, that is correct. The sender is just to the left and down a little from the Thermal Sensor. Just one wire.....right above the oil filter..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TommyBB »</TD></TR><TR><TD CLASS="quote">If you wanted Ill give you mine. I know they work. ill take them off and ship them to you if youd like. off of my blown D16a6
just have to tell me where they are located. im pulling the motor this weekend. im looking for a zc to swap in so.</TD></TR></TABLE>
Thanks for the offer, but I have a new one here now, so Ill use that one. Thanks though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 »</TD></TR><TR><TD CLASS="quote">
Im sure I know the location your talking about. The wire itself has a black boot on it, correct? I had taken a look at that one last night, and I was pretty sure that the part I was given would not fit there.
I will have to get it back up on the hoist and check again, thanks guys!
Just as a side note, has anyone ordered this peice before and know for sure the correct Part Number from Honda USA?
</TD></TR></TABLE>Im sure I know the location your talking about. The wire itself has a black boot on it, correct? I had taken a look at that one last night, and I was pretty sure that the part I was given would not fit there.
