Suspension & Brakes Theory, alignment, spring rates....
squeaking and turning radius after new suspension
Old Aug 18, 2005 | 09:00 AM
k1dfreeze's Avatar
Default squeaking and turning radius after new suspension
after i installed my buddy club racing spec damper's on my ej8, sometimes when im either making a slow right turn or going up a ramp or sidewalk, i get a loud squeak and it feels and sounds like somethings rubbing...sometimes the sound is almost like a loud grinding sound...it gets pretty bad if im trying to make a u-turn too...the cars lowered a little over 2" from stock height with the damper setting right in the middle...any ideas what this could be? should i raise the car a little and see if im getting the same problems? i cant see any part where it would be rubbing
Old Aug 18, 2005 | 09:15 AM
MattD@Stoptech's Avatar
Default Re: squeaking and turning radius after new suspension (k1dfreeze)
sounds like you're rubbing the tires on the fender, or fender liner.
Old Aug 18, 2005 | 09:21 AM
k1dfreeze's Avatar
Default Re: squeaking and turning radius after new suspension (El Pollo Diablo)
probably fender, no liner...i used to have the car lowered 2" for 4 years with no problems, now i put the new system on, and im having these issues...i also have the buddy club upper pillow mount kit...could it be a problem in there? might just be loose bolt or install error yeah?
SlowSOHC-T
Honda Civic (2001 - 2005)
Jul 22, 2013 04:45 AM
bchap
Suspension & Brakes
Aug 6, 2009 01:32 PM
Riceball
Suspension & Brakes
May 25, 2007 09:03 PM
hardcorelolo
Jun 28, 2006 05:54 AM
DC2IntegraTypeR
Oct 24, 2003 11:09 AM
