Silencer cost engine damage?
Old Aug 18, 2005 | 08:44 AM
wpsadmin's Avatar
Default Silencer cost engine damage?
3 months ago, I install this
http://cgi.ebay.com/ebaymotors...ZWDVW
in my 4.5 inches Apexi Muffler due to cop trouble, I kind of hammered it in.. now it's stucked in there..
I do like the quite-ness it produces, and I was wonder does it damage my car cause I think the hole is little smaller than stock Type R muffler.
Old Aug 18, 2005 | 08:53 AM
MattD@Stoptech's Avatar
Default Re: Silencer cost engine damage? (wpsadmin)
lol
Old Aug 18, 2005 | 09:00 AM
DsITR's Avatar
....Is this for real..
Dave_B's Avatar
Do you see the screw/bolt in the pic. That's there for a reason....You bolt it in so it doesn't come out on the highway! Doh!
Old Aug 18, 2005 | 09:02 AM
SMZ GSR's Avatar
Default Re: (Dave_B)
Old Aug 18, 2005 | 09:03 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">I kind of hammered it in.. now it's stucked in there..</TD></TR></TABLE>
stucked? hammered?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">I was wonder does it damage my car cause I think the hole is little smaller than stock Type R muffler.
You should not have any damage other than what You caused yourself.
Modified by 1GreyTeg at 1:45 PM 8/18/2005
Old Aug 18, 2005 | 09:23 AM
wpsadmin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Do you see the screw/bolt in the pic. That's there for a reason....You bolt it in so it doesn't come out on the highway! Doh!</TD></TR></TABLE>
my muffler has 4.5" tip, and they claim it fits, when i got it, it was only slightly bigger than the hole, due to the fact I had to go to court that day(fighting a noise muffler ticket), I kind of hammer it in.
it's been 3 months, working fine, don't really feel decrease in HP.
Old Aug 18, 2005 | 09:28 AM
JDM Factor's Avatar
Don't worry about it then. First, why would hit something on your exhaust with a hammer? Did you take the screw out when you hammered it in or you just went ahead and just started whalin at it? lol
Old Aug 18, 2005 | 09:35 AM
wpsadmin's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Don't worry about it then. First, why would hit something on your exhaust with a hammer? Did you take the screw out when you hammered it in or you just went ahead and just started whalin at it? lol</TD></TR></TABLE>
it goes in 75% by itself, and I use the hammer to add other 25%.
Screw was totally un-necessary.
Old Aug 18, 2005 | 09:36 AM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Did you take the screw out when you hammered it in or you just went ahead and just started whalin at it? lol</TD></TR></TABLE>
Sometimes you just gotta git-r-done.
Old Aug 18, 2005 | 09:39 AM
JDM Factor's Avatar
Default Re: (wpsadmin)
Oh well that's not a problem you only messed it up 25 %
Old Aug 18, 2005 | 09:41 AM
waijsR's Avatar
i had my silencer in my apexi exhaust for a few days... yea its a pain in the *** to get out... I had to use a flathead screwdriver to get mine out but it should be okay and not hurt ur car....
Old Aug 18, 2005 | 09:44 AM
wpsadmin's Avatar
Default Re: (hpnotiq_ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpnotiq_ITR &raquo;</TD></TR><TR><TD CLASS="quote">i had my silencer in my apexi exhaust for a few days... yea its a pain in the *** to get out... I had to use a flathead screwdriver to get mine out but it should be okay and not hurt ur car....</TD></TR></TABLE>
Thanks. This board definitely need some more nice people like yourself...
Old Aug 18, 2005 | 09:56 AM
itr1244's Avatar
no~~ oh shiet.. u put silencer on?? it will fugg up your motor big time meh..
u better go take em out right NOW
Old Aug 18, 2005 | 12:17 PM
citrus3000psi's Avatar
Default Re: (itr1244)
why get an aftermarket muffler and put a siliencer in? Might as well just keep the stock exhuast and use a cutout...
Old Aug 18, 2005 | 12:28 PM
Bbasso's Avatar
To install and remove from the muffler keep the caR running, the flow of air helps to slide it in/out. try it.
Old Aug 18, 2005 | 01:07 PM
Addicted2Racing's Avatar
Default Re: Silencer cost engine damage? (Bbasso)
Maybe squeeze 200 shot nitrous and rev to 20,000 rpm will shoot it out. J/P
No, it will not cause engine damage!
Old Aug 18, 2005 | 01:25 PM
Black R's Avatar
25 Year Member
.....they make a removal tool too! LOL
Old Aug 18, 2005 | 02:21 PM
genetsang's Avatar
on a serious note. if you want to try to remove it... this is what i did years ago... i got a wire coat hanger. used the hook and shoved it inside the muffler and yanked the silencer out.
Old Aug 18, 2005 | 02:24 PM
Big Phat R's Avatar
Looks like one of these:
That's gonna be a bitch to get out now.
Old Aug 18, 2005 | 02:47 PM
JDM Factor's Avatar
Or you can try one of these, be careful though, you might pull off the entire axle-back!
Old Aug 18, 2005 | 02:55 PM
Def's Avatar
Def
My silencer sticks a bit as well. I just move it around a bit with a flathead screwdriver to "break the seal" then rev my engine up to about 2.5k RPM in neutral and it usually pops right out. The rev needs to be a good stab of the throttle to get some air moving back there, not a ***** 5% throttle rev.
Old Aug 18, 2005 | 05:18 PM
mugenracer's Avatar
FFS...get anything with a hook on the end of it and pull it out again!!!!!!!!!!
Old Aug 19, 2005 | 11:29 PM
VTEC_Club's Avatar
Default Re: (mugenracer)
hey I had one of those silencers..... one day I checked and it was gone.... Hmmm .... still wondering what happened to it.
Old Aug 20, 2005 | 10:56 AM
nightrider's Avatar
it's been 3 months, working fine, don't really feel decrease in HP.</TD></TR></TABLE>
i'm sure there is a decrease in hp. on my spoon n1, with the silencer in, there was 5 or 7 hp lost at the wheel.
