ITR Turbo + Hondata = whirring noise!
Been boosted for a while on stock ecu. Since it was swapped out for the Hondata, everytime when I start the car from cold, I get quite a loud 'whirring' noise (like a vacuum cleaner) for a few minutes and then it goes. WTF is it? Is it a feature on the P28 that is/isn't present on the stock P72/73 that could be causing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Sounds like the evap purge selenoid.</TD></TR></TABLE>
WTF is that?! Enlighten me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">P28 doesnt pick that up does it?</TD></TR></TABLE>
I don't believe it does, and should be unplugged. I thought the only issue the PCS would cause with a p28 is bogging at idle when intake temps exceed 150 degrees (If I am wrong, please correct me).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">WTF is that?! Enlighten me.</TD></TR></TABLE>
Ahhh. I did look at this closely to try and pinpoint the source of the noise and it seems like thats where the noise is coming from... So what exactly does it do?
When you say unplugged, you mean just disconnect the rubber hose connected to it and leave it open?
I believe it vents fumes from the fuel lines/tank. That goes to the "can" which filters the gases and then exits under the car into the atmosphere. (or something like that).
take out the system, plug the hole on the IM, and get a much crisper throttle response.
It does, it creates a vaccuum leak at idle since the purge evap system is slightly different than on an integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 »</TD></TR><TR><TD CLASS="quote">boosted ITR's = the best drug in the world.
Boosted Type R's are wayyy overrated these days. Its soo like 3 years ago.
lol
Man I miss mine. lol
</TD></TR></TABLE>Boosted Type R's are wayyy overrated these days. Its soo like 3 years ago.
lol
lol
withdrawals....
it happens when you try to go without that rush..
and ive had my R for almost 2 years now.
lol
</TD></TR></TABLE>withdrawals....
withdrawals....
I get over it everytime I boost in my Supra with the top off with my rear tires that are wider then 2 of my ITR wheels put together
withdrawals....
what do a 300 horsepower supra and a 600 horsepower supra have in common?
they both run 12's.
</TD></TR></TABLE>what do a 300 horsepower supra and a 600 horsepower supra have in common?
they both run 12's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">keep thinking that
just what the domestic guys in my area always say...
</TD></TR></TABLE>just what the domestic guys in my area always say...
