Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
13x8 wheel, 215 too skinny?
Old Aug 18, 2005 | 12:54 AM
Ben Ogle's Avatar
Default 13x8 wheel, 215 too skinny?
The tires would be 215/50/13 (tread width = 8.5") Kumho 710s and the wheels would be rota RBs at 13x8. Unfortunately the 710s dont come in any other 13" size (at least not on tire rack). Would the 215 tire be too skinny for the 8" wheel?
Or should I just go with the more expensive 225/45/13s from hoosier (AS05) just because of the width? Would I be losing anything by running a tire thats a bit skinny for the rim? Would I gain any stick from the extra width of the hoosier?
Only the RBs will fit over the 10.3" brakes so I cant run some diamond 13x7s or something. I suppose I could run some 14x7 diamonds but they are 17lbs (http://www.diamondracingwheels.com/RoadRaceSeries.htm) and the tires to match are ~21lbs .
Ben
Modified by Ben Ogle at 10:22 AM 8/18/2005
Old Aug 18, 2005 | 04:08 AM
DSPDA3's Avatar
Default Re: 13x8 wheel, 215 too skinny? (Ben Ogle)
I'm running a 215/50 A032R-S on my 13x8 Diamonds. Setup works quite nicely. However, if there was a 225 available in the Yok, I would run that. I've heard the V710 is a wide tire, compared to others in that same size. It's probably just as wide as a 225 Hoosier, but that's just speculation on my part.
Old Aug 18, 2005 | 04:32 AM
RexRacer19's Avatar
I ran V700s in that size on 13x8 wheels for a while. They worked well and had good even wear. Click my sig to see a pic w/them on.
Old Aug 18, 2005 | 04:35 AM
jsi's Avatar
jsi
They'll be just about perfect on a 13x8. I've run 205-60-13 Z211 (7.8" tw) on 13x8 last season without issues.
Old Aug 18, 2005 | 05:07 AM
Gearz's Avatar
Everyone I've seen who is running the 13" V710's are either on 13x8's or 13x9's. I have them on a set of 13x8 Keizers and they fit great. On 13x9's they get stretched out a bit but I don't think it's detrimental to grip or response.
Here's a pic of them on my CSP CRX
It would be nice if Kumho made these just a bit wider in a 225 size, but I really doubt they will. The Hoosier 225/45-13 A3S05 has a wider contact patch and a shorter sidewall and really works well on a 13x9 wheel.
-Brian Meyer
Old Aug 18, 2005 | 07:31 AM
Ben Ogle's Avatar
Thanks guys.
Ben
chrisc543
Apr 16, 2014 11:33 AM
Liquidgsr
Honda S2000
24
Oct 16, 2010 05:00 AM
Powered by Honda
12
Aug 4, 2005 04:47 AM
skierd
Feb 25, 2005 07:01 PM
Rory Breaker
Mar 7, 2004 10:07 AM
