swapping d16z6 in for my d15 got some wiring harness questions
Old Aug 17, 2005 | 11:07 PM
sparxx's Avatar
Default swapping d16z6 in for my d15 got some wiring harness questions
I have a 92 dx w/ d15 in it that is about to die.I'm going to buy a d16z6 with harness, tranny, ect.I want to know if I will have to remove the dash or any dash components to swap the harness(I havn't removed carpet yet)..I've never owned anything but ef's so I guess I'm a newb to eg...so if any EGog's can help I thank you in advance.also will keeping a/c and p/s be a problem for this swap.thanks
Old Aug 17, 2005 | 11:54 PM
siregcivic's Avatar
it will all bolt up and the harness will connect and everything... all u need to do is 2 wires for vtec solinoid and pressure switch
Old Aug 18, 2005 | 12:03 AM
siregcivic's Avatar
Default Re: (siregcivic)
on the vtec solinoid there is 1 wire that needs to go to the ecu.... and the vtec pressure switch the black wire goes to a ground and the other goes to the ecu... you obviously dont need to worry about all the other crap since its pinouts for a b series... all u need is pressure switch and vtec solinoid
Old Aug 18, 2005 | 12:15 AM
sparxx's Avatar
but I'm using the d16z6 wiring harness and ecu, so I don't think I will have to rewire for vtec, but will I have to remove anything form the dash to get old harness out and new one in?
Old Aug 18, 2005 | 12:37 AM
siregcivic's Avatar
oh you have the full harness from ecu to firewall? okay remove the battery and battery box then it should pull through... thats all... the drivers side connectors will be fine... just the passanger side where it goes to the ecu
Old Aug 18, 2005 | 01:00 AM
sparxx's Avatar
thank you very much
Old Aug 19, 2005 | 06:32 PM
sparxx's Avatar
one more thing, do I have to drain the freon from the system or can I just unbolt it from the motor, pull the motor, drop the other one in and bolt the a/c back up?or should I get it discharged first?is there a big probability that the freon will leak during this?this will be my first swap that included an a/c system and I really don't want to pay to get it recharged if I don't have to.
Old Aug 20, 2005 | 03:05 AM
siregcivic's Avatar
you can unbolt the ac pump from the motor... run a string or wire through one of the mount holes and tie it up to the radiator support.... i always just take the ac out.. i like haveing a lot of room to move the motor around.. youll see what i mean when u go to swap the motor in... good luck it should be an easy swap
Old Aug 20, 2005 | 03:22 AM
VWVORTEX's Avatar
didn't all 92 civics come pre wired for vtec, why buy a new harness ?... i'm not 100% sure but i would look into that first before you spent extra..
Old Aug 24, 2005 | 03:06 AM
sparxx's Avatar
so your telling me I wouldn't have to change the wiring harness at all?would I have to add any wires anywhere?is the dx/lx harness the same as si/ex?
Modified by sparxx at 4:33 AM 8/24/2005
Old Aug 24, 2005 | 03:43 AM
b204dr's Avatar
Default Re: (GripStar)
pre wired some not all
Old Aug 24, 2005 | 08:21 AM
@(o_o)@'s Avatar
Default Re: (b204dr)
yea some are prewired...when i did my swap in my 92 civic, it was just plug and play for the d16z6...
Old Aug 26, 2005 | 06:22 AM
slambedcivic's Avatar
Default Re: (Tmoua86)
all 92 civics were wired for VTEC. just use the z6 wiring harness...
Old Aug 26, 2005 | 07:45 AM
Doeboy's Avatar
plug and play as well, with the z6 harness.
Old Aug 26, 2005 | 11:55 AM
siregcivic's Avatar
only 92-95 civics that came pre wired for vtec are.....
92-95 civic ex/si
92-95 civic vx
92 civic cx
Old Aug 26, 2005 | 04:18 PM
TTM's Avatar
TTM
is it wired into your *** thats what it seems like
Old Aug 26, 2005 | 04:20 PM
siregcivic's Avatar
WHAT UP DUDE????? U TALKIN TO ME???
siregcivic's Avatar
PM SENT
beginmyhonda
16
Jan 4, 2009 07:03 PM
Manny86
Aug 17, 2006 07:55 PM
-[95cxhatch]-
Sep 9, 2003 07:10 PM
PotatoePAPA
Mar 22, 2003 04:25 PM
