Just installed some sedan door handles....
Old Aug 17, 2005 | 10:22 PM
MR Dan's Avatar
Default Just installed some sedan door handles....
Heres some pics of the rear door handle install. The Integra sedan rear door handles come pre-painted so make sure to chose frost white since its easier to prep before the CW is sprayed...This is a nice mod for break-in prevention since the locking/unlocking rod is removed as well as the key hole....
Just picked up from the body shop with fresh CW paint job....
Old Aug 17, 2005 | 10:26 PM
Opie's Avatar
Very very nice
What did it cost ya?
Old Aug 17, 2005 | 10:28 PM
Naruto's Avatar
Default Re: Just installed some sedan door handles.... (ITR908)
looks good A little bit more info would be nice...but I guess if I wanted to do that I could go off of the pics BTW, how much did those cost?
MR Dan's Avatar
Default Re: (Opie)
My cost for the door handles were $52 a piece from Acura...the paint job cost me $30...so about $130 for this mod....
Dont feel like typing all the details right now...so enjoy the pics for now....
Old Aug 17, 2005 | 10:29 PM
Naruto's Avatar
Default Re: (ITR908)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR908 &raquo;</TD></TR><TR><TD CLASS="quote">My cost for the door handles were $52 a piece from Acura...the paint job cost me $30...so about $130 for this mod.... </TD></TR></TABLE>
something definitely to invest in
Old Aug 17, 2005 | 10:34 PM
MR Dan's Avatar
Default Re: (psychoticmindset)
BTW.....this is the rod you should remove to prevent break-ins.... no wonder thiefs pry the door handles to reach this rod...
(From both doors)
Old Aug 17, 2005 | 10:45 PM
DC2 to AP2's Avatar
looks good! i did the same thing. please make sure you have keyless entry
Old Aug 17, 2005 | 10:50 PM
MR Dan's Avatar
Default Re: (imola-red dc2)
Nice.......damn...my server is down for tonite.......my pics will be up again soon
Old Aug 17, 2005 | 11:02 PM
Naruto's Avatar
I was about to say! I'll check on this thread again tomorrow Thanks for the info!
Old Aug 17, 2005 | 11:03 PM
midwesta's Avatar
lookin good.
Old Aug 18, 2005 | 02:57 AM
Kavehman's Avatar
excuse my ignorance,
but will the central locking still work then if you remove the rod ?
Im not sure how the keyless entry works.
And would a possible cheaper way to do this be to just remove the rods and leave the key hole handles on ?
Old Aug 18, 2005 | 04:51 AM
Dave_B's Avatar
Hot **** mang. Never even knew there was a diff. in the sedan handles. Where these from the rear doors or something? Looks damn good and keeps things clean.
Old Aug 18, 2005 | 05:13 AM
MR Dan's Avatar
Default Re: Just installed some sedan door handles.... (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">excuse my ignorance,
And would a possible cheaper way to do this be to just remove the rods and leave the key hole handles on ?</TD></TR></TABLE>
yes the power lock system still works with the rod removed...plus you can just remove this rod with the original handles...
Old Aug 18, 2005 | 05:19 AM
cannan's Avatar
Its also a very subtle comestic mod...I think it looks clean without the key holes
Old Aug 18, 2005 | 05:28 AM
typer_696's Avatar
Default Re: Just installed some sedan door handles.... (RevHard)
LOOKS good really good check your remote batteries often
Old Aug 18, 2005 | 05:38 AM
nautica_t's Avatar
Default Re: Just installed some sedan door handles.... (typer_696)
i was contemplating doing this. i guess it makes me have even better reason to do it now.
Old Aug 18, 2005 | 06:25 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">LOOKS good really good check your remote batteries often</TD></TR></TABLE>
Well, if the remote fails, you can always climb in through the trunk.
Old Aug 18, 2005 | 06:29 AM
MR Dan's Avatar
Default Re: Just installed some sedan door handles.... (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">
Well, if the remote fails, you can always climb in through the trunk. </TD></TR></TABLE>
Old Aug 18, 2005 | 06:30 AM
penpen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Well, if the remote fails, you can always climb in through the trunk. </TD></TR></TABLE>
if you have a cage though, have fun playing in the monkey bars my battery has died before from the car being in storage, or is just disconnected for the same reason, so sometimes i need to use my key to lock up the car or get into it.
it's a tough call. if that's not a concern though, this is a very nice mod to do, good stuff
Old Aug 18, 2005 | 06:50 AM
WickedKP's Avatar
Default Re: Just installed some sedan door handles.... (penpen)
If you still left your factory power door lock motor then ulocking the trunk with your key if you didn't remove that key cylinder also will unlock both front door. I did the same thing about a yr ago and yes i had so far used my key few times to unlock the doors.
Old Aug 18, 2005 | 06:57 AM
RagingAngel's Avatar
Default Re: Just installed some sedan door handles.... (WickedKP)
That probably works for 98+ tegs...
but not for us ol'skool 97 Rs....
I've had a security guard try and tackle me cuz he thought I was breaking into my car as he saw me climbing into the trunk....
POS remote on my alarm!
Old Aug 18, 2005 | 06:59 AM
Bbasso's Avatar
It even looks good on PY
Old Aug 18, 2005 | 07:01 AM
Dave_B's Avatar
Default Re: Just installed some sedan door handles.... (Bbasso)
that's a nice red X there rob. I'd like to see it on PY.
Edit thanks
Old Aug 18, 2005 | 07:03 AM
Bbasso's Avatar
Default Re: Just installed some sedan door handles.... (Dave_B)
Works for me try again.
Old Aug 18, 2005 | 07:27 AM
Jay J's Avatar
Prince of Zamunda
Dont feel like typing all the details right now...so enjoy the pics for now.... </TD></TR></TABLE>
What bodyshop and where?
