Radio Bezel Removal
Remove the two screws in the side of the lower dash center piece once it is out of the way there is a single 8 mm bolt that holds the radio in the dash remove it and it should slide out the front panel.
If you're talking about the big charcoal bezel that's around the radio and switches and all, it's a bit different. It screws on from inside the dash. I had to pull the dash, pull the A/C ducting, pull the brackets, pull the other crap, then get in with a snake driver to get the screws. Good luck with it, if that's what you're asking about.
