Vacumm@Idle. What are you guys getting?
What is typical for a boosted honda? About -18/-20?
My car seems to run just fine, but my AEM is saying -9/-10 during idle. Do I have a vacumm leak of some sorts? When it does heat up the idle does kinda get funky every so often where the AF will just kinda jump from 12-14.7 and fluctuate a lil bit.
I was just messing with my AEM today and kinda noticed it so I thought I would get a 2nd opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg »</TD></TR><TR><TD CLASS="quote">.7 bar which is around 20-22 right?</TD></TR></TABLE>
20.6 inHg
20.6 inHg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda »</TD></TR><TR><TD CLASS="quote">^^^24-27in wow thats a lot...when my car runs...lol i see about 20-22in about 26 or so on decel</TD></TR></TABLE>
You are correct sir... had to run out to my car to test again... I see 22 inHg idling my car parked and 24-27 inHG decelerating
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">my gauge actually does read about -24in/hg at idle on my D. </TD></TR></TABLE>
your gauge is broken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">Doesn't a set of bad valve seals also affect this?
I get -18", I know my cyl. head is beat. </TD></TR></TABLE>
im not sure. i am fairly positive im burning oil from my valve seals, and i still pull 185-190 compression (b18b) and 20-22 idle vacuum
I see so smaller engine+bigger turbo must mean that you will see less vacuum. I have a b16 with T3T4 and I see -15in/hg at idle and about -20 at decel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner »</TD></TR><TR><TD CLASS="quote">I see so smaller engine+bigger turbo must mean that you will see less vacuum. I have a b16 with T3T4 and I see -15in/hg at idle and about -20 at decel.</TD></TR></TABLE>
i don't see how turbo size would effect your idle vacuum. -15 is way high. You should be lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">your gauge is broken
you are correct sir. I just checked the datalogs today and i idle at about 330mbar which is right around -20in/hg. I wonder why my gauge reads off in vacuum...it doesn't in boost
</TD></TR></TABLE>you are correct sir. I just checked the datalogs today and i idle at about 330mbar which is right around -20in/hg. I wonder why my gauge reads off in vacuum...it doesn't in boost
That's about 18-20 inhg from what I can tell.
