spark plugs/ header???????
Old Feb 23, 2002 | 09:50 AM
paulyman's Avatar
Default spark plugs/ header???????
guys whats a good spark plug to run
and i need some wires too
also where is a good place to find a dc sports header for a good price.
thanx
Old Feb 23, 2002 | 10:20 AM
fiebru1119's Avatar
Default Re: spark plugs/ header??????? (paulyman)
what are you driving?
Old Feb 23, 2002 | 10:21 AM
91DA9's Avatar
OEM wires are just fine. If you are not planning on any major modifications then I reccomend the Bosch Platinums, they can be had for like 10 bucks for all four from autozone. Bosch Wires are also good if they are less than OEM. Don't know about the header.
Old Feb 23, 2002 | 10:28 AM
fiebru1119's Avatar
Default Re: spark plugs/ header??????? (94IntegraGSR-OVR)
the service/parts guy at my acura dealer told me not to use anything but ngk platinum or coppers on my gsr... do u use bosch plat's? have you had any problems?
Old Feb 23, 2002 | 10:34 AM
mattL's Avatar
oem wires will do the job, but i felt a huge difference when i went to ngk's. my car idle's a lot smoother and feels stronger. for the 50-60 that they cost its worth it in my oppinion. as far as the header just do some calling around retail on one is 400 i can get you one for around 350, if youre interested IM me. mat
Old Feb 23, 2002 | 10:56 AM
1phatGSR's Avatar
Default Re: spark plugs/ header??????? (mattL)
don't get bosch platium plugs they are suck..stick wit NGK
Old Feb 23, 2002 | 04:26 PM
GSRaCeRbOI's Avatar
i would get NGK coppers.. copper is a better conductor of electricity... you'll have to change it a bit more often than the platinums.. but he'll the coppers are cheap and you can do the change and gap in about 10-15 mins...
for wires.. are your stock wires fried/really in need of replacement? if not i'd stick w/ stock.. if so.. you can look into NGK wires also.. their good and they dont cost that much ($60).. Bosch also has OEM replacements for around $60 at autozone i believe.. i havent priced OEM acura wires... magnecors are about $85.. but the NGKs, OEM or Bosch will be fine..
as for the header.. i have no idea.. sorry.. check http://www.groupbuycenter.com or check your local parts shops and online..
Old Feb 23, 2002 | 09:23 PM
drifter's Avatar
Default Re: spark plugs/ header??????? (GSRaCeRbOI)
Yes, i've also heard a gain of 1-3 whp going to copper spark plugs because they conduct electricity better. Very good cheap mod
Old Feb 24, 2002 | 09:23 AM
mickey513's Avatar
I just order factory oem wires for my 94gsr from ahmotor for $48, good price.
Ek2424
Mar 6, 2009 11:37 PM
Notorious_T
Feb 19, 2009 08:33 AM
raffydogg
Apr 24, 2008 09:43 AM
Jamied
11
Mar 2, 2006 04:08 PM
acura0gsr0ntegra
Oct 15, 2003 04:08 PM
