a question about making my ls block 2.0 using crv parts
From: gravity rides everything...everything will fall, se GA/ne FL
the blocks and bore are the same aren't they? so can i simply just put in the parts into my ls block? what do i need...like the crank and rods or what? are the b20b pistons the same compression as the ls one's also? thanks a lot for any help.
