i have no more clutch pressure..!??!
i was driving home from work.. then out of no where i stalled, and the clutch pedal felt easy. then finally there was no more stiffness, and my cltuch pedal was stuck to the floor.
it will move back and forth but there is no pressure, i checked the clutch reservoir and its full.
any heads up??
Modified by Nations Sickest CRX at 3:58 AM 8/18/2005
Modified by Nations Sickest CRX at 3:59 AM 8/18/2005
any heads up??
Well it could be a few things.
Clutch master cylinder could have taken a **** on you. Check for fluid around your clutch pedal inside the car.
I had this problem on a type R, check to see if your clutch master cylinder is leaking.
ok, now i replaced the clutch master cylinder, the clutch is engadging.. but i have to push the pedal all the way to the floor, sometimes/most of the time it wont even go into gear... any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nations Sickest CRX »</TD></TR><TR><TD CLASS="quote">ok, now i replaced the clutch master cylinder, the clutch is engadging.. but i have to push the pedal all the way to the floor, sometimes/most of the time it wont even go into gear... any ideas?</TD></TR></TABLE>
Did you bleed your clutch line after replacing the MC?
skhell
Transmission & Drivetrain
Jun 23, 2010 12:11 AM
