air fuel gauge help!!!!!
Old Aug 17, 2005 | 05:20 PM
migizzel's Avatar
Default air fuel gauge help!!!!!
does anybody know how to install one of these i boght one but lost the instructions there is only three wires green ,red ,black i know what Red and Black are but don't know where to hook up the green wire please help
Modified by migizzel at 6:32 PM 8/17/2005
Old Aug 17, 2005 | 05:33 PM
Reelizmpro's Avatar
Default Re: air fuel gauge help!!!!! (migizzel)
Well isn't it obvious? it goes to the oxygen sensor wiring.
Old Aug 17, 2005 | 05:40 PM
TH33G4MON3's Avatar
wow I'm going to have that same problem here soon... wish I could help... check the manufacturers site you might find something you never know...
Old Aug 17, 2005 | 05:41 PM
TH33G4MON3's Avatar
Default Re: air fuel gauge help!!!!! (Reelizmpro)
the 02 sensor to the cat?
Old Aug 17, 2005 | 05:44 PM
migizzel's Avatar
well i hooked the green wire to the 02 sens now the gauge read all the way over on the ritch side even if the car is not running any ideas?
Old Aug 17, 2005 | 05:46 PM
Reelizmpro's Avatar
Gauges will typically do full sweep if it's not getting a reading from the sensor, just power. Check the connection to the oxygen sensor wiring first. If it's good, check the back of the gauge to see if it says what wire goes where. The black may actually be for the sensor and green for ground...you never know.
Old Aug 17, 2005 | 06:21 PM
migizzel's Avatar
by the way these is a FAZE air/fuel gauge anybody has any in there car?
Old Aug 17, 2005 | 07:45 PM
migizzel's Avatar
ok whent back to the car i got the red wire hooked to the + batt the black one to a ground on the chassis and the green one to the 02 sensor i only have one before the catt butt no results it stays on even if u shut the car off well i guess that's the worst 60 dlls i've spend
Old Aug 17, 2005 | 08:01 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">ok whent back to the car i got the red wire hooked to the + batt the black one to a ground on the chassis and the green one to the 02 sensor i only have one before the catt butt no results it stays on even if u shut the car off well i guess that's the worst 60 dlls i've spend </TD></TR></TABLE>
Or you could go to advance auto or autozone and ask them to look at a set of the instructions
Old Aug 17, 2005 | 08:05 PM
or you could call faze customer support 1800 228 7667
Old Aug 17, 2005 | 08:08 PM
JK_Motorsports's Avatar
Ya you bought a pretty light show!!!!
Anyways, Something is not right, when in open air or not running, the gauge should read right lean. An o2 sensor puts out it's max voltage when no fuel is detected. That is if you put the key to the on position.
But anyways again, the gauge will not be accurate(Narrowband A/F gauges aren't in the first place) until the sensor heats up.
Old Aug 17, 2005 | 08:15 PM
Reelizmpro's Avatar
Well you're supposed to hook up the red wire to a switched 12V source...not straight to the battery! That's why it's staying on and draining your battery in the process. Anyway, I'm sure there are instructions on how to hook up an AF gauge online somewhere.
Old Aug 17, 2005 | 09:15 PM
Redline130's Avatar
Default Re: air fuel gauge help!!!!! (bumblezc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumblezc &raquo;</TD></TR><TR><TD CLASS="quote">Ya you bought a pretty light show!!!!
Exactly what I was thinking. A/F ratio gauges are useless.
Old Aug 19, 2005 | 02:08 PM
TH33G4MON3's Avatar
Default Re: air fuel gauge help!!!!! (Redline130)
it is pretty that is true haha
JDM1civic
Apr 8, 2007 08:10 AM
95jdmd15bswap
Aug 20, 2005 07:53 PM
nick32
Honda S2000
14
Apr 17, 2005 04:44 PM
