need help with distributor wiring b16a in 97 ex
Old Aug 17, 2005 | 05:18 PM
roguecivic97's Avatar
Default need help with distributor wiring b16a in 97 ex
i purchased an aftermarket high output ignition coil and i just switched it back to stock b/c i don't think it was made for a vtec motor, after putting it back to stock my check engine light came on and won't go off, i reset the ecu by unplugging the battery terminal and left it off for 5 minutes. still, check engine light on, i replaced the spark plugs, again, same thing. i don't know if a wire got switched around or whatnot inside the distributor, but i'm pretty sure it didn't. there are two wires connected to the ignition coil, one is at the negative terminal and is a yellow wire with a blue stripe and then there is a black wire with a yellow stripe at the positive terminal. both were switched from stock on the coil when i put them back in, but the bottom of those wires, where they connect to the distributor came off, and i think i have them in the right place. there are three areas where they can be plugged. the one closest to the tranny is already black and yellow, but the top two i'm not exactly sure which goes to which. can anyone post a diagram or help me out with what could possibly be wrong?
Old Aug 18, 2005 | 03:37 AM
Default Re: need help with distributor wiring b16a in 97 ex (roguecivic97)
anyone think they can help?
Jaynik
46
Dec 4, 2013 05:29 PM
nicks00si
Oct 12, 2011 09:00 AM
94gsr
Jun 1, 2004 12:55 PM
H23vtecEG
Oct 14, 2003 05:02 PM
PatrickGSR94
Mar 15, 2003 02:58 PM
