How much trouble am I in?
Old Aug 17, 2005 | 05:08 PM
LSEGHATCH's Avatar
Default How much trouble am I in?
I dropped this bolt #17
down into where the timing belt runs and was able to get it once but then it dropped down again and now I can't find it? I've been working all day on this **** and I'm shakey as hell.....i need help badly
Old Aug 17, 2005 | 05:10 PM
e jay one's Avatar
Default Re: How much trouble am I in? (LSEGHATCH)
i wouldnt leave it in there.
Old Aug 17, 2005 | 05:11 PM
95DxSi-R2
Guest
Posts: n/a
i wouldn't leave it in there, u have a chance of breaking a gear or screwing up your timing belt
LSEGHATCH's Avatar
Default Re: How much trouble am I in? (95DxSi-R2)
I know but how can i access it?
Old Aug 17, 2005 | 05:14 PM
e jay one's Avatar
take it all off as in the crank pulley and then the bottom cover. its gonna be some work but dont leave it.
Old Aug 17, 2005 | 05:15 PM
e jay one's Avatar
Default Re: How much trouble am I in? (e jay one)
or maybe fish around in there with a magnet.
Old Aug 17, 2005 | 05:16 PM
freakasis's Avatar
hate to tell ya but: your gonna have to pull the crank pulley, and lower timing cover. and yeah DO NOT leave it in there. i left a socket under my hood once and it wound up in there, killed my brand new oem timing belt. i was luckey and that was all, you might not be lucky.
smokee's Avatar
if you dropped it into the lower timing belt cover, you are gonna have to pull the lower cover and get the bolt out. you run the risk of really messing up the timing belt, or if it got caught in between the belt and the pully/gears it could cause the belt to jump teeth and mess up your valve train.
i am the king of dropping bolts into stuff, first time i had the carbs off a motorcycle, i dropped a bolt down into the head. there are these telescoping magnetic jobbers that help alot for getting them out.
http://www.harborfreight.com/c...91518
LSEGHATCH's Avatar
bolt retreived
Old Aug 17, 2005 | 05:17 PM
Deemeetree's Avatar
Electrician
A good adjustable-shaft magnetic. Or, remove everything.
Old Aug 17, 2005 | 05:18 PM
smokee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">bolt retreived</TD></TR></TABLE>
good work butterfingers
Old Aug 17, 2005 | 05:26 PM
b20lsvtecCivic's Avatar
when u drop it the first time how did u get it out...
use a extended magnic or get a piece of magnic and tie a rope to it
and start fishing ahahha lolz
hope that works..
Old Aug 17, 2005 | 05:42 PM
-L@ndry-'s Avatar
Default Re: How much trouble am I in? (b20lsvtecCivic)
next time you drop a bolt and cant find it,drop another and watch where it falls J/K
Old Aug 17, 2005 | 05:50 PM
Maness's Avatar
Default Re: How much trouble am I in? (jdm5lug)
Come on now, we need to know how! Did use use the neato magnetic things, or wiggle your little fingers in there somehow or what!? lol
Old Aug 17, 2005 | 06:21 PM
nocturnaldragon's Avatar
Default Re: How much trouble am I in? (Maness)
I think he somehow miniaturized himself and repelled himself down in there and attached a rope (really a string but it might as well of been a rope to him) then fought his way out of the labyrinth and de miniaturized himself and pulled it out.
Now I cant be entirely certain but that's what I think happened. PROVE ME WRONG!
Old Aug 17, 2005 | 06:29 PM
Combustion Contraption's Avatar
Old Aug 17, 2005 | 06:51 PM
Jorsher's Avatar
I did the same thing once, I just bought one of those telescopic magnet things and fished it out.
Old Aug 17, 2005 | 07:03 PM
LSEGHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">I think he somehow miniaturized himself and repelled himself down in there and attached a rope (really a string but it might as well of been a rope to him) then fought his way out of the labyrinth and de miniaturized himself and pulled it out.
Now I cant be entirely certain but that's what I think happened. PROVE ME WRONG!</TD></TR></TABLE>
Close, actually not at all
I was working on my car all day, kinda warm here and working as fast as possible (not a good thing) so by dusk is when I dropped the bolt.
The first time I go it with a claw type thing that can fish into small areas, and then the second time I was so tired and stressed that I came down here to post and my dad took a wack at it and go it in about 10 sec. He said it was in plain sight (this is where the fast working and stress played a roll) I was looking way too hard and too fast.
Sorry the story couldn't be a little better but... hey I'm glad the bolt is out
Old Aug 17, 2005 | 07:10 PM
95DxSi-R2
Guest
Posts: n/a
sweet, now don't drop it again
Old Aug 17, 2005 | 07:19 PM
LSEGHATCH's Avatar
I know, I think I'm going to start puting rags in open spaces so stuff like this doesn't happen again.
kKdARIAN's Avatar
Vice President/CEO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">sweet, now don't drop it again</TD></TR></TABLE>
heh... been there done that many times..
if your shakey, hold off.. take a break then go back at it...
freakasis's Avatar
you could have made up a better story.
Old Aug 17, 2005 | 07:25 PM
Maness's Avatar
Default Re: (freakasis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakasis &raquo;</TD></TR><TR><TD CLASS="quote">you could have made up a better story.</TD></TR></TABLE>
yeah cause we're ****** for good stories.
new thread title
"Almost Killed: Bolt"
Old Aug 17, 2005 | 07:32 PM
LShatchie's Avatar
Default Re: (Maness)
same thing happened to me last week
Old Aug 17, 2005 | 08:10 PM
midwesta's Avatar
wh0000000
