Putting a speedo with tach into a 91 civic hatch, need help
So i found a speedo with a tach out of a 90 civic hatch and need to put it into my 91 that had no tach. I noticed that the pins do not correctly align, does anyone have the diagram of how to wire my 91 so it works with the 90 tach/speedo?
Does this help?
http://img63.exs.cx/my.php?loc...t.jpg
Got it here:
https://honda-tech.com/zerothread?id=1073157
Hoping it does, I am not a wiring master but I did some searching and that looked like it would help me when I plan on doing something similar.
Got it here:
Are you talking about a guage/instrument cluster?
If you are talking about putting a '90 civic guage cluster into you '91, there are no wiring difference and it is a straight swap.
If you are not talking about guage clusters, refer to the post above mine.
i was talking about a gauge cluster, but i had three plugs on the back of the cluster in my 91 civic dx, plus the speedometer, the normal two and the third is a small blue one. The cluster i got only has two and the speedometer, is there a way to adapt it to work in my dx?
HI91EFHB
May 29, 2009 01:14 PM
JokerTypeR
Jul 21, 2006 07:23 PM
