code 15 after dash removal
first things first. i removed my dashboard out and i painted my dashboard solid black.
after putting everything back and start my car...it wouldnt start. its cranking over but wont start. i looked at the error code..its giving me code#15 (IGNITION OUTPUT SIGNAL). i notice my stereo doesnt work either. i've pulled each and every fuse i see under the dash and in the underhood fuse box. each of them are good. i also notice as i turned my headlights on...i hear the beeping sound.(approximately when you put the key in the ignition and the door is open..you hear the beeping sound). check engine light is on without the key in the ignition. throwing the code#15.
im now stuck. pls help. all help is greatly appreciated.
yeah I just took my dash out to paint it but mines still runs I know theres a code because it wont rev to 8g anymore but im to lazy to look what code and you can use vinyl spray paint to paint the dash I got it at autozone.
sounds like u crushed a wire under there take out the dash and have a look
hmmm..i'll check on that later on today after mowing the lawn and keep you guys updated. damn it sucks being at home without a job.
i just used regular spray paint (gloss black with clear coat)..looks very clean. i sand it down to get it smooth and primered it then i wet sand it. primered it again cause i was getting the orange peel look..then wet sand it...then primered it a few more times and wet sand it...finally after primering it 6 times and wet sanding it....2 coats of the gloss black paint and 3 coats of clear.....looks good.
i took my time doing it.[Modified by vsual, 11:27 AM 2/23/2002]
why did u paint your dash was it messed up before
as for the problem that i encountered about code#15....i took my dashboard out and looked at the wires closely..did not see anything wrong with it. put everything back and tried starting the car...it wouldnt start. looked at the ecu if it was throwing any code errors...nothing. tried cranking over again..no progress...wtf??anyone have an idea??
b18c-gsr
Jan 30, 2025 04:40 AM
