Did I get screwed?!?! Dash Clock........
I purchased a OEM clock for my VX. I plugged it in and it's not working. Is there power running to the plug or is there a extra fuse that needs to be installed OR did I just take it up the a$$ and spend $20 on a broken P.O.S.............
mine plugged right in and worked perfectly on my VX.
double check that your fuses are ok. if the clock doesn't work with the key in Run then there may be something wrong with the clock.
if you have a volt/ohm meter check for the following:
wht/blu - constant power (clock memory)
yel - 12v in Run or Crank (main power)
red/blk - power with lights on (dims with lights)
blk - ground (main ground)
StevenPacheco
Lighting
May 12, 2010 11:36 AM
